06-25-2009 04:31 AM - edited 03-15-2019 06:41 PM
It's a long shot but has anyone any experience on connecting an ISDN10 from SingTel in Singapore to a CME on a 2811 router? I guessing a VWIC2-1MFT-T1/E1 would be the right interface card?
What framing and line code are required also is this a PRI or R2 type trunk?
A sample working config would be greatly appreciated.
Solved! Go to Solution.
06-25-2009 04:38 AM
That is the right card. As the name says, it's ISDN PRI. You configure pri-group with ten channels and that's it. You also need a minimum of pvdm2-16.
06-25-2009 04:38 AM
06-26-2009 12:48 AM
Thanks.
07-16-2013 07:34 AM
Were you able to get this to work?
I am looking at some Cisco docs that say it's supported in 2900 only
07-16-2013 07:46 AM
You are responding to a 4 years thread, that was marked solved.
Anyway, ISDN PRI works on all cisco router, not just 2900.
