SIP/2.0 404 Not Found Error on Incoming Calls
Abayomi Smith
Hi All,
I would appreciate any help concerning this issue.
I am unable to make or receive calls. I receive SIP/2.0 404 Not Found on incoming call.
My setup is as thus;
CUCM-----------CUBE----------SIP Gateway
Please find attached part of the config of the CUBE and also output of debug ccsip message of test call from 02071871717 to 02038897551.
Y.
Called Number=02038897551. The significant digits field is set to ALL.​
So, you have translation pattern configured to convert the called number to internal extension?
How are the internal extensions configured and assigned to the phones?
//Suresh Please rate all the useful posts.
17 Replies 17
Hi, it seems like issue with your dial-peer config.
can you try configure the below dial-peers and let me know how it works?
also you should try binding the right interfaces in the dial-peers
voice-class sip bind control source-interface <LAN interface towards CUCM ex: gig0/0>
 voice-class sip bind media source-interface <LAN interface towards CUCM ex: gig0/0>
dial-peer voice 1000 voip
 description **Inbound call from SIP Trunk**
 session protocol sipv2
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 1001 voip
 description **Inbound call to CUCM**
 destination-pattern 020388975[0-6].
 session target ipv4:10.127.33.3
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 1002 voip
 description **Outgoing Call to SIP Trunk**
 destination-pattern .T
 session target ipv4:88.XX.XX.169
voice-class sip bind control source-interface <WAN interface towards ITSP ex: gig0/1>
 voice-class sip bind media source-interface <WAN interface towards ITSP ex: gig0/1>
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
Thanks Suresh,
However I am still unable to get any calls through. Instead now I get nothing...Just silence. No ringback nothing.
When I check the debug ccsip messages I get a SIP/2.0 503 Service Unavailable-No Bandwidth Available and also a SIP/2.0 500 Internal Server Error.
When I did a debug of the dial-peer just to check if the right dial peer is being matched, I get this
dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Nov 20 19:36:06.650 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=02038897500T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Nov 20 19:36:06.650 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=02038897500
*Nov 20 19:36:06.650 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchPeertype:
*Nov 20 19:36:06.650 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1002 Is Matched
*Nov 20 19:36:06.650 GMT: //-1/4DCAD934-7023-11E4-93CF-FBC03BACF4BB/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_VIA_URI; URI=sip:88.XX.XX.169:5060
*Nov 20 19:36:06.650 GMT: //-1/4DCAD934-7023-11E4-93CF-FBC03BACF4BB/DPM/dpMatchPeertype:
*Nov 20 19:36:06.650 GMT: //-1/4DCAD934-7023-11E4-93CF-FBC03BACF4BB/DPM/dpMatchCore:
   Result=-1
This shows its matching dial-peer 1002, which is the outgoing dial-peer, instead of 1000.
Also  the calling number seems to be the first number in the DDI range 02038897500 however I am calling from 02071871717.
I don't have redirect header on inbound calls ticked on the sip trunk config. I believe it should show the originating no is the URI
Y
Hi.
Just few questions
Did you ckeck that you correctly configured trunk destination address on CUCM?
Can incoming CSS configured on trunk reach internal extensions?
Can you please add these lines on your cube:
voice service voip
no ip address trusted authenticate
Please add also the output of a debug ccdip mess while calling outbound
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks Carlo,
The CSS configured for inbound calls on the trunk can reach the partition of internal extensions.
I added the command no ip address trusted authenticate   but there was still no luck. will post the debug ccsip messages output on external calls soon.
Y
It would also be useful to include "debug voip ccapi inout" with your next ccsip output.  This will help to confirm which Dial Peers are being selected by CUBE.
Rob
Hi Robert,
Thank you for replying.
Please find below the debug output as requested. It seems to be matching the outgoing dial peer 1001 though its configured as an incoming dial peer.
Also I noticed the calling number shows as 02038897500 (which is the first  DDI no within the range rather than 02071871717, which the call is originating from)
sh dial-peer voi sum
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
1000   voip  up   up                                0  syst sip-server
1001   voip  up   up             020388975[0-6].    0  syst ipv4:10.127.33.3
1002   voip  up   up             .T                 0  syst ipv4:88.XX.XX.169
1010   voip  up   up             1[6-8]..           0  syst ipv4:10.4.10.100
1020   voip  up   up             75[0-6].           0  syst ipv4:10.127.33.3
AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22A61424, Call Info(
   Calling Number=02038897500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=02038897551(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2368
*Nov 21 12:35:16.698 GMT: //-1/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCheckClipClir:
   In: Calling Number=02038897500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=02038897500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Nov 21 12:35:16.702 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 21 12:35:16.702 GMT: :cc_get_feature_vsa malloc success
*Nov 21 12:35:16.702 GMT:  cc_get_feature_vsa count is 17
*Nov 21 12:35:16.702 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:596161576,feature_id:2368
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=02038897500(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=02038897551(TON=Unknown, NPI=Unknown))
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_process_call_setup_ind:
   Event=0x22D29E38
*Nov 21 12:35:16.702 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 02038897551
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCallSetContext:
   Context=0x3C29C970
   >>>>CCAPI handed cid 2368 with tag 1000 to app "_ManagedAppProcess_Default"
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCallProceeding:
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1001, Params=0x39EAFEC4, Progress Indication=NULL(0)
*Nov 21 12:35:16.702 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCheckClipClir:
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCheckClipClir:
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=02038897551, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=02038897500, Final Destination Flag=TRUE,
   Guid=AE300164-70B1-11E4-A024-FBC03BACF4BB, Outgoing Dial-peer=1001
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=02038897500
   ----- ccCallInfo IE subfields -----
   cisco-ani=02038897500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=02038897551
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22A61424, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=02038897500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=02038897551(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Nov 21 12:35:16.706 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 21 12:35:16.706 GMT: :cc_get_feature_vsa malloc success
*Nov 21 12:35:16.706 GMT:  cc_get_feature_vsa count is 18
*Nov 21 12:35:16.706 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:596157768,feature_id:2369
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccCallSetContext:
   Context=0x39EAFE74
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccSaveDialpeerTag:
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Nov 21 12:35:16.706 GMT: //2368/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/ccGet_xc_nr_asp_info:
*Nov 21 12:35:16.706 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_api_event_indication:
   Event=188, Call Id=2369
   Event Is Sent To Conferenced SPI(s) Directly
*Nov 21 12:35:16.706 GMT: //2368/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 21 12:35:16.706 GMT: cc_api_get_xcode_stream : 4819
*Nov 21 12:35:16.706 GMT: //2369/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 21 12:35:16.710 GMT: //2369/AE300164-70B1-11E4-A024-FBC03BACF4BB/CCAPI/cc_api_call_proceeding:
   Interface=0x22A61424, Progress Indication=NULL(0)
*Nov 21 12:35:16.710 GMT: //2369/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 21 12:35:16.710 GMT: cc_api_get_xcode_stream : 4819
*Nov 21 12:35:16.710 GMT: //2368/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Y
Is there any chance you can post your current config again just need to see any changes you've made since posting the original config.
Rob
HI Robert,
Thanks.
Please find below
voice-card 0
 dsp services dspfarm
voice call convert-discpi-to-prog
voice call debug full-guid
voice rtp send-recv
voice service voip
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  no update-callerid
  early-offer forced
  midcall-signaling passthru
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice register global
license udi pid CISCO2911/K9 sn FCZ1834605X
hw-module pvdm 0/0
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
redundancy
ip tcp synwait-time 5
class-map match-any voice-rtp
 match ip precedence 5
 match ip dscp ef
 match ip rtp 16384 16383
class-map match-any voice-cntl
 match ip precedence 3
 match ip dscp af31
 match access-group name voice-signal
policy-map QoS-LAN-Policy
 class voice-rtp
  set cos 5
 class voice-cntl
  set cos 3
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description **connection to SIP Gateway**
 ip address XX.197.XX.188 255.255.255.248
 duplex auto
 speed auto
interface GigabitEthernet0/1
 backup interface GigabitEthernet0/2
 ip address 10.127.32.129 255.255.255.128
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.127.22.254
ip route 79.XX.XX.69 255.255.255.255 XX.197.XX.185
ip route 79.XX.XX.70 255.255.255.255 XX.197.XX.185
ip route 88.XX.XX.169 255.255.255.255 XX.197.XX.185
ip route 88.XX.XX.170 255.255.255.255 XX.197.XX.185
control-plane
ccm-manager music-on-hold
ccm-manager config server 10.127.33.3
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.127.33.3 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 description conference bridge
 associate ccm 1 priority 1
 associate profile 3 register Conf_bridge
 associate profile 2 register MTP-transcode
 associate profile 1 register MTP-CCM
dspfarm profile 2 transcode
 codec g729r8
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 10
 associate application SCCP
dspfarm profile 3 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 1
 shutdown
dspfarm profile 1 mtp
 codec pass-through
 codec g711ulaw
 maximum sessions software 20
 session target sip-server
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
 voice-class sip bind control source-interface GigabitEthernet0/1
 voice-class sip bind media source-interface GigabitEthernet0/1
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
 session target ipv4:88.xx.xx.169
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dial-peer voice 1010 voip
 description Internal Calls to field Extension 1600-1899
 destination-pattern 1[6-8]..
 session target ipv4:10.4.1.1
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 1020 voip
 destination-pattern 75[0-6].
 incoming called-number 75[0-6].
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 retry invite 4
 timers connect 100
 sip-server ipv4:88.XX.XX.169
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 10.127.32.129 port 2000
 max-ephones 25
Hi.
did you have any chance to capture a debug ccsip message while calling out?
Please let me know.
Carlo
Hi Carlo,
I am sorry for the late response. Please find the debug output below.
The outgoing call works fine. Its just a problem with incoming calls.
I also noticed a weird behavior today which wasn't happening before.
I am unable to make any call when the hand set is picked up. As soon as I press a key on the dial-pad I get a fast busy signal. However with the handset down I am able to make calls. Nothing has changed from yesterday when it was working. Any clues?
"Toprak x7550" <sip:+442038897550@10.127.33.3>
Remote-Party-ID: "Toprak x7550" <sip:+442038897550@10.127.33.3>;party=calling;screen=yes;privacy=off
Contact: <sip:+442038897550@10.127.33.3:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
*Nov 21 16:03:07.357 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07848599599@88.XX.XX.169:5060 SIP/2.0
Via: SIP/2.0/UDP XX.197.XX.188:5060;branch=z9hG4bK7182448
Remote-Party-ID: "Toprak x7550" <sip:+442038897550@XX.197.XX.188>;party=calling;screen=yes;privacy=off
From: "Toprak x7550" <sip:+442038897550@XX.197.XX.188>;tag=5C90238-9E9
To: <sip:07848599599@88.XX.XX.169>
Date: Fri, 21 Nov 2014 16:03:07 GMT
Call-ID: B79517A5-70CE11E4-A784FBC0-3BACF4BB@XX.197.XX.188
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3907596288-0000065536-0000000015-0051871498
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1416585787
Contact: <sip:+442038897550@XX.197.XX.188:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 5926 6518 IN IP4 XX.197.XX.188
s=SIP Call
c=IN IP4 XX.197.XX.188
t=0 0
m=audio 22502 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Nov 21 16:03:07.357 GMT: //2958/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.127.33.3:5060;branch=z9hG4bKede19562
From: "Toprak x7550" <sip:+442038897550@10.127.33.3>;tag=1614~011e7165-c217-6f7c-cc4f-b72f3ab7b02e-29093277
To: <sip:07848599599@10.127.32.129>
Call-ID: e8e93000-46f16249-f-3177f0a@10.127.33.3
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M6a
Content-Length: 0
*Nov 21 16:03:07.361 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Nov 21 16:03:07.417 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Require: 100rel
RSeq: 1
To: <sip:07848599599@88.XX.XX.169>;tag=3625574618-717280
CSeq: 101 INVITE
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Contact: <sip:07848599599@88.XX.XX.169:5060>
Accept: application/sdp
Content-Length: 213
v=0
o=MSX49 35546258079464325 1 IN IP4 88.XX.XX.169
s=sip call
c=IN IP4 88.215.63.170
t=0 0
m=audio 24568 RTP/AVP 8 101
a=fmtp:101 0-15
a=sendrecv
*Nov 21 16:03:07.421 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:07848599599@88.XX.XX.169:5060 SIP/2.0
Via: SIP/2.0/UDP XX.197.XX.188:5060;branch=z9hG4bK719399
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
*Nov 21 16:03:07.425 GMT: //2958/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:07848599599@10.127.32.129>;tag=5C9027C-CE5
CSeq: 101 INVITE
Remote-Party-ID: <sip:07848599599@10.127.32.129>;party=called;screen=yes;privacy=off
Contact: <sip:07848599599@10.127.32.129:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 9613 6843 IN IP4 10.127.32.129
s=SIP Call
c=IN IP4 10.127.32.129
t=0 0
m=audio 22500 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
*Nov 21 16:03:07.433 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
*Nov 21 16:03:11.645 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Require: 100rel
RSeq: 2
CSeq: 101 INVITE
Content-Length: 0
*Nov 21 16:03:11.645 GMT: //2958/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Remote-Party-ID: <sip:07848599599@10.127.32.129>;party=called;screen=no;privacy=off
Content-Length: 0
*Nov 21 16:03:11.649 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP XX.197.XX.188:5060;branch=z9hG4bK71AD2B
CSeq: 103 PRACK
RAck: 2 101 INVITE
Max-Forwards: 70
Content-Length: 0
*Nov 21 16:03:11.661 GMT: //2959/E8E93000-0001-0000-0000-000F03177F0A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Y.
Hi.
On dial-peer 1000 try this:
incoming called-number 020388975T
after that post the output of a debug voip dial-peer inout
Carlo
Hi Carlo,
Thanks.
The result is still the same.
Please find below the output as requested
Dial peer 1000 isn't being matched.
xxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Nov 21 17:14:08.089 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=02038897551, Called Number=02038897551, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=02038897551
   Result=Success(0) after DP_MATCH_DEST
*Nov 21 17:14:08.089 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=02038897551, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Nov 21 17:14:08.089 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1001
     2: Dial-peer Tag=1002
*Nov 21 17:14:08.089 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=02038897500, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1001
*Nov 21 17:14:08.093 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Nov 21 17:14:08.093 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Nov 21 17:14:08.093 GMT: //-1/A32DC48F-70D8-11E4-AC06-FBC03BACF4BB/DPM/dpAssociateIncomingPeerCore:
   Calling Number=02038897500, Called Number=02038897551, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1000
*Nov 21 17:14:08.093 GMT: //-1/A32DC48F-70D8-11E4-AC06-FBC03BACF4BB/DPM/dpMatchSafModulePlugin:
*Nov 21 17:14:08.101 GMT: //-1/A32DC48F-70D8-11E4-AC06-FBC03BACF4BB/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=02038897551, Peer Info Type=DIALPEER_INFO_SPEECH
*Nov 21 17:14:08.101 GMT: //-1/A32DC48F-70D8-11E4-AC06-FBC03BACF4BB/DPM/dpMatchSafModulePlugin:
   dialstring=02038897551, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Nov 21 17:14:08.101 GMT: //-1/A32DC48F-70D8-11E4-AC06-FBC03BACF4BB/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Nov 21 17:14:08.101 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Nov 21 17:14:08.101 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Nov 21 17:14:08.101 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Nov 21 17:14:08.101 GMT: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=02038897551, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Y
From the output we can see that DP 1000 is correctly matched
There must be something on  Trunk config on CUCM.
Can you please post a screenshot of Trunk configuration on CUCM?
Carlo
Thanks Carlo,
Must have missed that when going through the Debug output. Its been a long day and been starring at screens all day. Apologies.
Please find the trunk config page as requested.
Many Thanks,
Y
