SIP/2.0 488 Not Acceptable Media
Good day!
I'm kinda lost here so I would like you opinion with this, I have a couple of users that are not able to make outbound calls while others can (they are dialing the same number). I checked the device profile, line, and phone they are using and everything is the same.
Both calls hit the same voice router (15.2(4)M2) and I'm not that good reading SIP debug yet but I can definitely a difference between a call and the other, failing with
Warning: 304 10.191.152.210 "Media Type(s) Unavailable"
But I dont have any idea of how to fix it, a few links I found that it could be related with SRTP or a coded problem, but I'm not seeing anything that can confirm that.
Attaching the debug ccsip all, any suggestion?
Rolando A. Valenzuela
2 Accepted Solutions
Deepak Mehta
It is codec issue as logs are pointing out.
Either you can use a transcoder and apply to SIP trunk device pool,or  make sure the audio codec preference list which you have set on inbound voip dial-peer has all codecs listed( G729br8,G729 etc).
2776168: .Jun 16 08:08:05.004: //188286/A07AFF800001/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
2776169: .Jun 16 08:08:05.004: //188286/A07AFF800001/SIP/Error/sipSPIDoAudioNegotiation:
Media negotiation failed for m-line 1
2776170: .Jun 16 08:08:05.004: //188286/A07AFF800001/SIP/Error/sipSPIDoMediaNegotiation:
no valid fax or audio streams
2776171: .Jun 16 08:08:05.004: //188286/A07AFF800001/SIP/Error/sipSPIHandleInviteMedia:
Media Negotiation failed for an incoming call>>>>>>>>>>>>>>>>.
2776172: .Jun 16 08:08:05.004: //188286/A07AFF800001/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:65, category:278
2776173: .Jun 16 08:08:05.004: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[188286], src[6]
2776174: .Jun 16 08:08:05: %VOICE_IEC-3-GW: SIP: Internal Error (INVITE, codec mismatch): >>>>>>>>>>>>>>>>>>
IEC=1.1.278.7.110.0 on callID 188286
2776175: .Jun 16 08:08:05.008: //188286/A07AFF800001/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_UNACCEPTABLE_MEDIA_ERR>>>>>>>>>>>>>
2776176: .Jun 16 08:08:05.008: //188286/A07AFF800001/SIP/Error/sipSPIContinueNewMsgInvite:
Unacceptable media indicated for INVITE
Please try to  other codecs eg g729br8 codec in this list and paste the output is still doesn't work.thanks
8 Replies 8
Deepak Mehta
Thanks for the reply Deepak, since this is an outgoing call to the PSTN the dial-peer that it will uses will be
dial-peer voice 13 pots
 description LONG-DISTANCE CALLS
 translation-profile outgoing 12
 destination-pattern 90[1-9]........
 port 0/0/0:15
 forward-digits 10
and since is pots the codec commad is not available, I will need to set up that on the voip one (which is for incoming calls)
dial-peer voice 2 voip
 destination-pattern ....$
 session protocol sipv2
 session target ipv4:10.10.215.10
 incoming called-number .
 voice-class codec 1
 dtmf-relay rtp-nte sip-kpml sip-notify
 no vad
is that what you are suggestion? the gateway it self already have a dspfarm
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 6
 associate application SCCP
Thanks for the help!
yes , i have mentioned voip dial-peer inbound so your understanding is correct.
what is in voice class codec 1? does it have all codecs listed?
Also the transcoder has to be applied on the SIP trunk on CUCM which is pointing to the GW .
I will rather fix it in the router is possible, this is class codec 1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 isac mode independent bit-rate 32000 framesize 30
 codec preference 3 g729r8
What will be your suggestion? change the class codec or list the codecs on the dial-peer? what I dont understand is why the mismatch is present only for certain users while the configuration seems to be equal everywhere.
That made the trick Deepak, thank you so much!!
2781820: .Jun 17 08:02:21.443: //191508/FDDA83800001/SIP/Media/sipSPISelectCodecVersion: g729br8 flavor of g729 codec will be used
2781821: .Jun 17 08:02:21.443: //191508/FDDA83800001/SIP/Info/sipSPIDoAudioNegotiation: Codec (g729br8) Negotiation Successful on Static Payload for m-line 1
Sent:
SIP/2.0 100 Trying
Sent:
SIP/2.0 183 Session Progress
Sent:
SIP/2.0 200 OK
Received:
BYE sip
Thanks again.
Good work my friend.
Cheers !!!
I have the same issue, but unable to fix.
ESVDLRT03#
Nov 21 17:53:51: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060 SIP/2.0
Via: SIP/2.0/UDP 109.167.99.99;rport;branch=z9hG4bKeN30ge78c09XB
Route: <sip:918221791@80.28.123.9:5060>
Max-Forwards: 66
From: "0013034604405" <sip:0013034604405@109.167.99.99>;tag=j4Sc0FmBKgmmS
To: <sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060>
Call-ID: 5643a6dc-8722-1238-fc98-02426da76363
CSeq: 12623823 INVITE
Contact: <sip:918221791@109.167.99.99:5060>
User-Agent: VozManager-DpServer/sip4 (2.9.0)
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, NOTIFY
Supported: path, replaces
Allow-Events: talk, hold, conference, refer
Privacy: none
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 261
P-Charging-Vector: icid-value=40251855A020C3823057D335-1121-17535105;orig-ioi=IMS.VODAFONE.ES;icid-generated-at=TSC101.IMS.VODAFONE.ES
P-Early-Media: supported
X-Did: 918221791
P-Asserted-Identity: "0013034604405" <sip:0013034604405@109.167.99.99>
v=0
o=root 1574336263 1574336264 IN IP4 109.167.99.99
s=root
c=IN IP4 109.167.99.99
t=0 0
m=audio 18968 RTP/AVP 8 0 1018000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=rtpmap:8 PCMA/
Nov 21 17:53:51: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=918221791, Called Number=918221791, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=918221791
Result=Success(0) after DP_MATCH_DEST
Nov 21 17:53:51: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=918221791, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Nov 21 17:53:51: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=101
2: Dial-peer Tag=100
3: Dial-peer Tag=102
4: Dial-peer Tag=10
Nov 21 17:53:51: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=0013034604405, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=10
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Nov 21 17:53:51: //-1/547A569CBEAD/DPM/dpAssociateIncomingPeerCore:
Calling Number=0013034604405, Called Number=918221791, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
Nov 21 17:53:51: //-1/547A569CBEAD/DPM/dpMatchSafModulePlugin:
Sent:
To: <sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060>;tag=7DD3A0D4-1C34
Date: Thu, 21 Nov 2019 16:53:51 GMT
Allow-Events: telephone-event
Warning: 304 192.168.1.100 "Media Type(s) Unavailable"
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.2.4.M6
Content-Length: 0
Received:
ACK sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060 SIP/2.0
Max-Forwards: 66
CSeq: 12623823 ACK
Content-Length: 0
Received:
OPTIONS sip:10.205.2.5:5060 SIP/2.0
Via: SIP/2.0/TCP 10.254.5.52:5060;branch=z9hG4bK69be37877ac5c
To: <sip:10.205.2.5>
Call-ID: 7d39ff00-dd61c11f-56893-3405fe0a@10.254.5.52
User-Agent: Cisco-CUCM11.5
CSeq: 101 OPTIONS
Contact: <sip:10.254.5.52:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Calling Number=, Called Number=, Voice-Interface=0x0,
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Nov 21 17:53:51: //-1/5493F8BDBEB1/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:51: //-1/5493F8BDBEB1/DPM/dpMatchSafModulePlugin:
Sent:
SIP/2.0 200 OK
To: <sip:10.205.2.5>;tag=7DD3A178-20CA
CSeq: 101 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 372
v=0
o=CiscoSystemsSIP-GW-UserAgent 6442 8820 IN IP4 10.205.2.5
s=SIP Call
c=IN IP4 192.168.1.100
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Nov 21 17:53:54: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.254.5.53:5060;branch=z9hG4bK19d596bfaa185
Date: Thu, 21 Nov 2019 16:53:54 GMT
Call-ID: 7f03c280-dd61c122-19b1a-3505fe0a@10.254.5.53
CSeq: 101 OPTIONS
Contact: <sip:10.254.5.53:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Nov 21 17:53:54: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:54: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 21 17:53:54: //-1/56486196BEB2/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:54: //-1/56486196BEB2/DPM/dpMatchSafModulePlugin:
Sent:
SIP/2.0 200 OK
To: <sip:10.205.2.5>;tag=7DD3ACA4-33
CSeq: 101 OPTIONS
Content-Length: 372
v=0
o=CiscoSystemsSIP-GW-UserAgent 9528 8558 IN IP4 10.205.2.5
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Nov 21 17:53:57: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.254.5.51:5060;branch=z9hG4bK1a7e237475059
Date: Thu, 21 Nov 2019 16:53:57 GMT
Call-ID: 80cd8600-dd61c125-19c45-3305fe0a@10.254.5.51
CSeq: 101 OPTIONS
Contact: <sip:10.254.5.51:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Nov 21 17:53:57: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:57: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 21 17:53:57: //-1/582204B8BEB3/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:57: //-1/582204B8BEB3/DPM/dpMatchSafModulePlugin:
Sent:
SIP/2.0 200 OK
To: <sip:10.205.2.5>;tag=7DD3B8C4-2041
CSeq: 101 OPTIONS
Content-Length: 372
v=0
o=CiscoSystemsSIP-GW-UserAgent 6539 3435 IN IP4 10.205.2.5
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Nov 21 17:53:59: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:9985484426790@192.168.1.100:5060;received=80.28.123.9:5060 SIP/2.0
Via: SIP/2.0/UDP 109.167.99.99;rport;branch=z9hG4bKF20yNg4FrX39H
Route: <sip:9985484426790@80.28.123.9:5060>
Max-Forwards: 70
From: <sip:mod_sofia@109.167.99.99:5060>;tag=6X0tZNc6amySe
To: <sip:9985484426790@oasip.trunksip.me>
Call-ID: 820935d0-7036-4c3b-a4d6-e647dd587589_39F5DBB8-CC8C11E8-B201F5E5-D84721D4
CSeq: 13562191 OPTIONS
Contact: <sip:mod_sofia@109.167.99.99:5060>
Content-Length: 0
Nov 21 17:53:59: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=mod_sofia, Called Number=, Voice-Interface=0x0,
Nov 21 17:53:59: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 21 17:53:59: //-1/5921C31EBEB4/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:53:59: //-1/5921C31EBEB4/DPM/dpMatchSafModulePlugin:
Nov 21 17:53:59: //1573045/5921C31EBEB4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:9985484426790@oasip.trunksip.me>;tag=7DD3BF50-3D2
Date: Thu, 21 Nov 2019 16:53:59 GMT
Content-Length: 375
v=0
o=CiscoSystemsSIP-GW-UserAgent 3999 2437 IN IP4 192.168.1.100
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 109.167.99.99;rport;branch=z9hG4bKHNv9H807NcS5B
Max-Forwards: 66
From: "0013034604405" <sip:0013034604405@109.167.99.99>;tag=5pSmFyH4m5SKr
Call-ID: 5bb651a5-8722-1238-fc98-02426da76363
CSeq: 12623828 INVITE
Privacy: none
Content-Length: 308
P-Charging-Vector: icid-value=40251855A020D56730794FDE-1121-17540006;orig-ioi=IMS.VODAFONE.ES;icid-generated-at=TSC301.IMS.VODAFONE.ES
X-Did: 918221791
v=0
o=root 1574328534 1574328535 IN IP4 109.167.99.99
s=root
t=0 0
m=audio 26706 RTP/AVP 8 18 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
4: Dial-peer Tag=10
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:54:00: //-1/59ED0252BEB5/DPM/dpAssociateIncomingPeerCore:
Nov 21 17:54:00: //-1/59ED0252BEB5/DPM/dpMatchSafModulePlugin:
Nov 21 17:54:00: //-1/59ED0252BEB5/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=0013034604405
----- ccCallInfo IE subfields -----
cisco-ani=0013034604405
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=918221791
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Nov 21 17:54:00: //-1/59ED0252BEB5/CCAPI/cc_api_call_setup_ind_common:
Interface=0x221DD8C, Call Info(
Calling Number=0013034604405,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=918221791(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1573046
Nov 21 17:54:00: //-1/59ED0252BEB5/CCAPI/ccCheckClipClir:
In: Calling Number=0013034604405(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=0013034604405(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 17:54:00: :cc_get_feature_vsa malloc success
Nov 21 17:54:00: cc_get_feature_vsa count is 9
Nov 21 17:54:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:283535856,feature_id:121756
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=0013034604405(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=918221791(TON=Unknown, NPI=Unknown))
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/cc_process_call_setup_ind:
Event=0x156958A0
Nov 21 17:54:00: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 918221791
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccCallSetContext:
Context=0x1465A504
>>>>CCAPI handed cid 1573046 with tag 10 to app "_ManagedAppProcess_Default"
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccCallProceeding:
Nov 21 17:54:00: //-1/59ED0252BEB5/DPM/dpMatchPeersCore:
Calling Number=, Called Number=918221791, Peer Info Type=DIALPEER_INFO_SPEECH
dialstring=918221791, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Nov 21 17:54:00: //-1/59ED0252BEB5/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=100
2: Dial-peer Tag=101
4: Dial-peer Tag=10
Result=SUCCESS(0)
4: Dial-peer Tag=10
Result=SUCCESS(0)
4: Dial-peer Tag=10
Calling Number=918221791, Called Number=, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
Result=SUCCESS(0)
4: Dial-peer Tag=10
Result=SUCCESS(0)
4: Dial-peer Tag=10
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=100, Params=0x12A2ED1C, Progress Indication=NULL(0)
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccCheckClipClir:
Destination Pattern=918221[67].., Called Number=918221791, Digit Strip=FALSE
Redirect Number=, Display Info=0013034604405
Account Number=0013034604405, Final Destination Flag=TRUE,
Guid=59ED0252-0BB6-11EA-BEB5-F5E5D84721D4, Outgoing Dial-peer=100
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=918221791
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x221DD8C, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=0013034604405,(Calling Name=0013034604405)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=918221791(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov 21 17:54:00: cc_get_feature_vsa count is 10
Nov 21 17:54:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:283533392,feature_id:121757
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/ccCallSetContext:
Context=0x12A2ECCC
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccSaveDialpeerTag:
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/ccGetMediaClassTag:
media class tag 0
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccGetMediaClassTag:
media class tag 0
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccSetMediaclassIp2ipTags:
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
Nov 21 17:54:00: //1573046/59ED0252BEB5/CCAPI/ccGet_xc_nr_asp_info:
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/cc_api_event_indication:
Event=188, Call Id=1573047
Event Is Sent To Conferenced SPI(s) Directly
Nov 21 17:54:00: //1573046/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov 21 17:54:00: cc_api_get_xcode_stream : 4819
Nov 21 17:54:00: //1573047/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov 21 17:54:00: //1573047/59ED0252BEB5/CCAPI/cc_api_call_proceeding:
Interface=0x221DD8C, Progress Indication=NULL(0)
Nov 21 17:54:00: //1573046/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 21 Nov 2019 16:54:00 GMT
Content-Length: 0
Nov 21 17:54:00: //1573047/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:918221791@10.254.5.51:5060 SIP/2.0
Via: SIP/2.0/UDP 10.205.2.5:5060;branch=z9hG4bKB23C71A84
Remote-Party-ID: "0013034604405" <sip:0013034604405@10.205.2.5>;party=calling;screen=no;privacy=off
From: "0013034604405" <sip:0013034604405@10.205.2.5>;tag=7DD3C48C-2AD
To: <sip:918221791@10.254.5.51>
Call-ID: 59EE3AA2-BB611EA-BEBBF5E5-D84721D4@10.205.2.5
Min-SE: 1800
Cisco-Guid: 1508704850-0196481514-3199596005-3628540372
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6
CSeq: 101 INVITE
Timestamp: 1574355240
Contact: <sip:0013034604405@10.205.2.5:5060>
Expires: 180
Max-Forwards: 65
Content-Disposition: session;handling=required
Content-Length: 264
v=0
o=CiscoSystemsSIP-GW-UserAgent 4089 1219 IN IP4 10.205.2.5
s=SIP Call
c=IN IP4 10.205.2.5
t=0 0
m=audio 17226 RTP/AVP 18 101
c=IN IP4 10.205.2.5
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Nov 21 17:54:01: //1573047/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:918221791@10.254.5.51>;tag=299582~1bf5267a-9cdc-4bc4-8e40-a73690294251-69683976
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM11.5
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 55bcf70000105000a000007e95fc7c5d;remote=6cce15b6b4dfd7fd1f0cf837ab299582
P-Asserted-Identity: "Daniel Suarez" <sip:34918221791@10.254.5.51>
Remote-Party-ID: "Daniel Suarez" <sip:34918221791@10.254.5.51>;party=called;screen=yes;privacy=off
Contact: <sip:918221791@10.254.5.51:5060>;+u.sip!devicename.ccm.cisco.com="SEP007E95FC7C5D"
Content-Length: 0
Nov 21 17:54:01: //1573047/59ED0252BEB5/CCAPI/cc_api_call_alert:
Interface=0x221DD8C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Nov 21 17:54:01: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov 21 17:54:01: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 21 17:54:01: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
4: Dial-peer Tag=10
Nov 21 17:54:01: //1573046/59ED0252BEB5/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Calling Number=, Called Number=0013034604405, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=0013034604405
Result=SUCCESS(0)
1: Dial-peer Tag=10
Nov 21 17:54:01: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=34918221791, Called Number=, Voice-Interface=0x0,
Nov 21 17:54:01: //1573046/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060>;tag=7DD3C624-126D
Remote-Party-ID: "Daniel Suarez" <sip:34918221791@192.168.1.100>;party=called;screen=yes;privacy=off
Contact: <sip:918221791@192.168.1.100:5060>
Content-Length: 0
Nov 21 17:54:09: %SEC-6-IPACCESSLOGNP: list 25 denied 0 104.206.128.6 -> 0.0.0.0, 1 packet
Nov 21 17:54:16: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:918221791@192.168.1.100:5060;received=80.28.123.9:5060 SIP/2.0
Max-Forwards: 66
CSeq: 12623828 CANCEL
Reason: Q.850;cause=16
Content-Length: 0
Nov 21 17:54:16: //1573046/59ED0252BEB5/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x221DD8C, Call Id=1573046
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov 21 17:54:16: //1573047/59ED0252BEB5/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Nov 21 17:54:16: //1573046/59ED0252BEB5/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Nov 21 17:54:16: //1573046/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 21 Nov 2019 16:54:16 GMT
Content-Length: 0
Nov 21 17:54:16: //1573047/59ED0252BEB5/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:918221791@10.254.5.51:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1574355256
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
Content-Length: 0
Received:
Max-Forwards: 66
CSeq: 12623828 ACK
Content-Length: 0
Nov 21 17:54:16: //1573046/59ED0252BEB5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x221DD8C, Tag=0x0, Call Id=1573046,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Nov 21 17:54:16: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 17:54:16: :cc_free_feature_vsa freeing 10E669E8
Nov 21 17:54:16: vsacount in free is 9
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Nov 21 17:54:16: //1573047/59ED0252BEB5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x221DD8C, Tag=0x0, Call Id=1573047,
Nov 21 17:54:16: :cc_free_feature_vsa freeing 10E66048
Nov 21 17:54:16: vsacount in free is 8
Received:
CSeq: 101 INVITE
Content-Length: 0
Sent:
ACK sip:918221791@10.254.5.51:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
