SIP Call issues on LAN using ISR 4331
dastrix80
Hi Guys,
Can anyone assist? Im making a Sip call from a Doorbird intercom to a Zoipher soft client. Registration works, but theres no call :(
Some debug:
Aug  9 05:48:06.663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1002@192.168.0.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.141:5060;rport;branch=z9hG4bKPj5243d63d-847b-43a0-85f4-bda6a7a68173
Max-Forwards: 70
From: sip:1001@192.168.0.254;tag=5159bd80-0fd7-4b86-ba08-221492722657
To: sip:1002@192.168.0.254
Contact: <sip:1001@192.168.0.141:5060;ob>
Call-ID: 88d7d6d4-9934-4c7e-a8a8-2572572bd674
CSeq: 12312 INVITE
Call-Info: <http://192.168.0.141/bha-api/image.cgi> ;purpose=icon, <http://192.168.0.141/bha-api/> ;purpose=info
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Session-Expires: 1800
Min-SE: 90
Content-Type: application/sdp
Content-Length:   551
v=0
o=- 3742782486 3742782486 IN IP4 192.168.0.141
s=doorbird
b=AS:84
t=0 0
a=X-nat:0
m=audio 4106 RTP/AVP 0 8 96
c=IN IP4 192.168.0.141
b=TIAS:64000
a=rtcp:4107 IN IP4 192.168.0.141
a=sendrecv
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-16
m=video 4108 RTP/AVP 97
a=rtcp:4109 IN IP4 192.168.0.141
a=sendonly
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42e01e; packetization-mode=1; sprop-parameter-sets=Z00AKNoBQBbpUgAABPAAAGLAwIAB6EgACJVF73wvCIRq,aO48gA==
Aug  9 05:48:06.667: //578/9F9D7E9E81C1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 09 Aug 2018 05:48:06 GMT
CSeq: 12312 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.3.7
Session-ID: 00000000000000000000000000000000;remote=5487c4303256562796b44c17e8b20225
Content-Length: 0
Aug  9 05:48:11.672: //578/9F9D7E9E81C1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: sip:1002@192.168.0.254;tag=BA0471-8EE
CSeq: 12312 INVITE
Reason: Q.850;cause=38
Content-Length: 0
Aug  9 05:48:11.691: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1002@192.168.0.254 SIP/2.0
Max-Forwards: 70
CSeq: 12312 ACK
Content-Length:  0
Aug  9 05:48:19.504: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Aug  9 05:48:33.102: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.141:5060;rport;branch=z9hG4bKPj6881be9a-8074-4479-9c37-cbc3f02f74d3
Max-Forwards: 70
From: sip:1001@192.168.0.254;tag=15a1fc2b-87fb-45cd-8bfd-db30c5c16f1b
Call-ID: d2d3a545-8e49-4e72-9a3b-8182d0c5752c
CSeq: 15045 INVITE
Min-SE: 90
Content-Length:   551
v=0
o=- 3742782512 3742782512 IN IP4 192.168.0.141
s=doorbird
b=AS:84
t=0 0
a=X-nat:0
m=audio 4110 RTP/AVP 0 8 96
b=TIAS:64000
a=rtcp:4111 IN IP4 192.168.0.141
a=sendrecv
a=fmtp:96 0-16
m=video 4112 RTP/AVP 97
a=rtcp:4113 IN IP4 192.168.0.141
a=sendonly
Aug  9 05:48:33.108: //582/AF5F9E4481C8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 09 Aug 2018 05:48:33 GMT
CSeq: 15045 INVITE
Session-ID: 00000000000000000000000000000000;remote=9953feb9a8b65c878a55ee1c849210ff
Content-Length: 0
Aug  9 05:48:34.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Aug  9 05:48:38.109: //582/AF5F9E4481C8/SIP/Msg/ccsipDisplayMsg:
Sent:
To: sip:1002@192.168.0.254;tag=BA6BB6-1951
CSeq: 15045 INVITE
Content-Length: 0
Aug  9 05:48:38.123: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 15045 ACK
Content-Length:  0
AND
ISR4331-KK#  debug ccsip error
SIP Call error tracing is enabled
ISR4331-KK#
Aug  9 05:51:14.949: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
SIP: (587) Attribute mid, level 1 instance 1 not found.
SIP: (587) Attribute mid, level 2 instance 1 not found.
SIP: (587) setup attribute, level 1 instance 1 not found.
SIP: (587) connection attribute, level 1 instance 1 not found.
SIP: (587) Attribute label, level 1 instance 1 not found.
SIP: (587) a=framerate attribute, level 1 instance 1 not found.
SIP: (587) setup attribute, level 2 instance 1 not found.
SIP: (587) connection attribute, level 2 instance 1 not found.
SIP: (587) Attribute label, level 2 instance 1 not found.
SIP: (587) a=framerate attribute, level 2 instance 1 not found.
SIP: (587) Attribute ptime, level 2 instance 1 not found.
Aug  9 05:51:14.954: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
 Unexpected VoIPCodec Type :No Codec
SIP: (589) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug  9 05:51:19.577: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
 SIP Message incomplete, trashed
Aug  9 05:51:19.956: //589/0FD780FF81D0/SIP/Error/sipTransportPostSendFailure:
 Posting send failure msg with tcb:0x0 reason=5
Aug  9 05:51:19.956: //589/0FD780FF81D0/SIP/Error/act_idle_send_msg_failure:
 Send Error to 1.129.105.230:63384 for transport TCP
Aug  9 05:51:19.956: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
 No Inbound Container Created !!!
Aug  9 05:51:19.956: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Aug  9 05:51:19.957: //589/0FD780FF81D0/SIP/Error/sipSPI_ipip_ExtractAndAddPassthruCopyListDataToContainer:
 Container is NULL
Aug  9 05:51:19.957: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Aug  9 05:51:19.957: //589/0FD780FF81D0/SIP/Error/sipSPIFlushDeferredQueue:
 Invalid deferredQueue
Aug  9 05:51:19.957: //-1/xxxxxxxxxxxx/SIP/Error/sipConnectionManagerUnregisterCtxtInConnection:
 Connection not found for addr=1.129.105.230, port=63384 local_addr=192.168.0.254
Aug  9 05:51:19.973: //587/0FD780FF81D0/SIP/Error/sipSPIFlushDeferredQueue:
Im quite new to Voice so im not really sure whats going on. My config is here:
voice service voip
 ip address trusted list
  ipv4 100.101.33.4
 allow-connections sip to sip
 h323
  call service stop
 sip
  bind control source-interface GigabitEthernet0/0/1
  bind media source-interface GigabitEthernet0/0/1
  registrar server expires max 1200 min 300
voice register global
 mode cme
 source-address 192.168.0.254 port 5060
 max-dn 10
 max-pool 10
 auto-register
voice register dn  1
 number 1001
 name Doorbird
voice register dn  2
 number 1002
 name Note8
voice register pool  1
 id mac 1CCA.E371.06FD
 number 1 dn 1
 username 1001 password 456456
 codec g711ulaw
voice register pool  2
 id mac 04D6.AA29.649C
 number 1 dn 2
 username 1002 password 789789
 codec g711ulaw
9 Replies 9
Under voice register global > no call service stop
Thank you, it was already shut down
voice service voip
  ipv4 0.0.0.0 0.0.0.0
 no ip address trusted authenticate
 h323
  call service stop
 sip
 and i still see two streams
 Connection not found for addr=1.129.111.75, port=63806 local_addr=192.168.0.254
*Aug  9 09:26:35.307: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Aug  9 09:26:35.308: //18/21FD37D98023/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Aug  9 09:26:35.308: //18/21FD37D98023/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:503, container:7FCB924348D8
*Aug  9 09:26:35.325: //18/21FD37D98023/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7FCB91318BD8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 1001
Called Number            : 1002
Source IP Address (Sig  ): 192.168.0.254
Destn SIP Req Addr:Port  : 192.168.0.141:5060
Destn SIP Resp Addr:Port : 192.168.0.141:5060
Destination Name         : 192.168.0.141
*Aug  9 09:26:35.325: //18/21FD37D98023/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.0.254
Source IP Port    (Media): 8008
Destn  IP Address (Media): 192.168.0.141
Destn  IP Port    (Media): 4192
Orig Destn IP Address:Port (Media): [ - ]:0
Media Stream             : 2
Negotiated Codec         : h264
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 97 (tx), 97 (rx)
Source IP Port    (Media): 8010
Destn  IP Port    (Media): 4194
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
Bit more debug
ISR4331-KK#debug ccsip messages
SIP Call messages tracing is enabled
ISR4331-KK#
Aug  9 09:32:46.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Aug  9 09:32:48.106: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.141:5060;rport;branch=z9hG4bKPj444e187b-7804-4929-b269-6fd11a3294bf
Max-Forwards: 70
From: sip:1001@192.168.0.254;tag=ad39db97-0dba-41a0-b15a-0d770bfc6e4c
Call-ID: f224350b-5e5a-4e94-90fc-8c5d12e7b630
CSeq: 9272 INVITE
Min-SE: 90
Content-Length:   551
v=0
o=- 3742795967 3742795967 IN IP4 192.168.0.141
s=doorbird
b=AS:84
t=0 0
a=X-nat:0
m=audio 4204 RTP/AVP 0 8 96
b=TIAS:64000
a=rtcp:4205 IN IP4 192.168.0.141
a=sendrecv
a=fmtp:96 0-16
m=video 4206 RTP/AVP 97
a=rtcp:4207 IN IP4 192.168.0.141
a=sendonly
Aug  9 09:32:48.112: //33/032E4BEC803B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 09 Aug 2018 09:32:48 GMT
CSeq: 9272 INVITE
Session-ID: 00000000000000000000000000000000;remote=a5101adda65c595183867ac1a8e8cc68
Content-Length: 0
Aug  9 09:32:53.113: //33/032E4BEC803B/SIP/Msg/ccsipDisplayMsg:
Sent:
To: sip:1002@192.168.0.254;tag=176200-1842
CSeq: 9272 INVITE
Content-Length: 0
Aug  9 09:32:53.132: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 9272 ACK
Content-Length:  0
I have confirmed its working on the LAN. So it seems I have an issue with Zone based firewall on the ISR transmitting the call across a WAN
I have opened up TCP & UDP all ports to the Private IP on the ISR (The Lan interface) which is what SIP listens on.
When i try and connect, I can register fine from the internet on my mobile SIP client. However, I cannot make a call. Nothing happens.
This works perfectly fine when on the LAN only.
I suspected RTP/SIP port issues but ive opened it ALL up, even turned off the Zone Based firewall. Still the same issue
I see this in SIP debug from the WAN
*Aug  9 10:51:50.148: //22/0AAC79AF801D/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.141:5060;rport;branch=z9hG4bKPjfff54bd8-c138-44b4-9bba-1b02fa3971e2
From: sip:1001@192.168.0.254;tag=1d5ecae4-8eca-42ef-902d-c8a183407c0c
To: sip:1002@192.168.0.254;tag=7B408-1E64
Date: Thu, 09 Aug 2018 10:51:45 GMT
Call-ID: e52c30e6-c303-43a0-95be-44b01113fa73
CSeq: 25456 INVITE
Session-ID: 00000000000000000000000000000000;remote=8c5bf8a3e08f59d090f9853515241c8a
Content-Length: 0
Hello
i think its network transport issue.
You can't sent invite until transport layer will acces.
Check:
sip
session transport tcp
or maybe your session transport udp
You can use debug ccsip all in maintanance window for show all info during a call.
What interface on ISR has "192.168.0.254" IP ? Enable the following and share the logs in a text file -
debug ccsip message
debug ccsip error
debug ccsip info
debug voice ccapi inout
Hello, I should clarify this router is a Cisco 3945 on 15.6 not an ISR. I have also tried  Version 15.2(3)T3
I'm also using NAT NVI.
I have placed those debugs on, but I dont get alot of outut.
Gig0/0 is the WAN interface, and obtains its IP via DHCP
Gig0/1 is in a Bridge group, with VLAN1. VLAN1 has ip address 192.168.0.254
3945-KK#debug ccsip message
3945-KK#debug ccsip error
3945-KK#debug ccsip info
SIP Call info tracing is enabled
3945-KK#debug voice ccapi inout
voip ccapi inout debugging is on
3945-KK#term mon
3945-KK#
*Aug 13 23:15:55.495: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:15:55.495: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:15:55.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:15:55.495: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:15:57.219: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:15:57.219: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:15:57.219: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
*Aug 13 23:16:10.503: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:10.503: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:10.503: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:16:10.503: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:16:25.515: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:25.515: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:25.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:16:25.515: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:16:27.231: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:27.231: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:27.231: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
*Aug 13 23:16:40.527: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:40.527: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:40.527: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:16:40.527: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:16:55.539: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:55.539: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:55.539: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:16:55.539: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:16:57.243: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:16:57.243: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:16:57.243: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
*Aug 13 23:17:10.547: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:17:10.547: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:17:10.547: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:17:10.547: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:17:25.551: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:17:25.551: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:17:25.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:17:25.551: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
*Aug 13 23:17:27.255: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:17:27.255: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:17:27.255: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
*Aug 13 23:17:40.563: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: MSG LINE READ FAILURE DUE TO RS->EOF
*Aug 13 23:17:40.563: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
*Aug 13 23:17:40.563: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
*Aug 13 23:17:40.563: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
 SIP Message incomp
It is an ISR - Integrated Services Router. Take the log again and in buffer with appropriate buffer space. Not on term mon. I don't see any call in these logs.
