Hi all,
I have been trying to make SIP calls from my Cisco 5300 RTR terminate to my ISP ( TATA) but still can’t get it to work call are getting disconnected after first Ring. Below are the equipment Involve.
E0 SIP Trunk
Nortel Switch ----------------->cisco 5300 RTR -------------------------> ISP
I see all calls hitting the dial-peer 4007 pots, and then hitting the dial-peer voice 4003 voip (test number is 912067343134). When I do a SIP TRACE using “debug ccsip messages” I see that my ISP is requesting “Require: timer”, like if the CALL setup Timer Expired . I increase the timer setup under “Sip” and set it to “min-se 48000” but still calls are being disconnected. I already checked my ISP and they are saying that the call is being disconnected on my side, and that they are using “codec g729r8”. I have the codec set to G729r8 on my side. Blow is the Sip Trace I did and attached are my configuration, debug ccsip all and debug voip ccapi inout.
Any Help and explanation of what is happening is Highly Appreciated and Thanks in advance for your assistance.
Call TRACE
BZE-AGGR-RAS03#
BZE-AGGR-RAS03#
BZE-AGGR-RAS03#
Mar 26 15:23:22.757:
Sent:
INVITE sip:912067343134@66.198.40.9:5060 SIP/2.0
Via: SIP/2.0/UDP 200.32.250.52:5060
To: <sip:912067343134@66.198.40.9>
Date: Tue, 26 Mar 2013 15:23:22 GMT
Call-ID: EE538216-955F11E2-8F58AB8F-15D318CD@200.32.250.52
Supported: timer
Require: 100rel
Min-SE: 1800
Cisco-Guid: 3998290142-2506035682-2404756367-366155981
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO
CSeq: 101 INVITE
Max-Forwards: 6
Remote-Party-ID: <sip:200.32.250.52>;party=calling;screen=no;privacy=off
Timestamp: 1364311402
Contact: <sip:200.32.250.52:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 6376 5818 IN IP4 200.32.250.52
s=SIP Call
c=IN IP4 200.32.250.52
t=0 0
m=audio 17266 RTP/AVP 18 101 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Mar 26 15:23:22.813:
Received:
SIP/2.0 100 Trying
To: <sip:912067343134@66.198.40.9>;tag=gK02b8326a
CSeq: 101 INVITE
Content-Length: 0
Mar 26 15:23:23.653:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Contact: <sip:912067343134@66.198.40.9:5060>
Allow: INVITE,ACK,CANCEL,BYE,REGISTER,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,OPTIONS
Require: 100rel
RSeq: 30141
Content-Length: 254
Content-Disposition: session; handling=required
v=0
o=Sonus_UAC 8605 9205 IN IP4 66.198.40.9
s=SIP Media Capabilities
c=IN IP4 66.198.40.7
t=0 0
m=audio 9928 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Mar 26 15:23:23.665:
Sent:
PRACK sip:912067343134@66.198.40.9:5060 SIP/2.0
CSeq: 102 PRACK
RAck: 30141 101 INVITE
Content-Length: 0
Mar 26 15:23:23.721:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Mar 26 15:23:29.761:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
Require: timer
Supported: timer,replaces
Session-Expires: 1800;refresher=uac
Content-Length: 0
Mar 26 15:23:29.769:
Sent:
Max-Forwards: 6
Content-Length: 0
CSeq: 101 ACK
Mar 26 15:23:29.773:
Sent:
BYE sip:912067343134@66.198.40.9:5060 SIP/2.0
Max-Forwards: 6
Timestamp: 1364311409
CSeq: 103 BYE
Content-Length: 0
Mar 26 15:23:29.837:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
Danny
Solved! Go to Solution.
From this logs now we see that the issue is with your provider..
We get a 180 ringing at 23:59:52...
Mar 26 23:59:52.431: Received:
SIP/2.0 180 Ringing
The gateway didnt get a 200 OK and after 20 sec the call was terminated
Mar 27 00:00:12.435: Sent:
CANCEL sip:912067343134@66.198.40.9:5060 SIP/2.0
You need to go back to your ITSP and find out whats going on..Why are they not sending a 200 OK response to our INVITE.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
On another note, I will suggest you enable PRACK again. It looks as if they want PRACK before they send a 200 OK.
Danny,
I am glad to have helped. So cals are working without PRACK?
Danny,
Yes its yoiur gateway that is sending the BYE immediately after receiving the 200 OK from the provider. It looks like your gateway expects some SDP in the 200 okay, but your provider is already sending SDP in 180 ringing.
You can try and disable PRACK and lets see if your ITSP will send media in 200 OK. According to the RFC the only time when the SDP attributes in 180/183 response differ to 200 OK is only when you use PRACK. SO if you disable PRACK and your ITSP doesnt send SDP in 200 OK exactly as is in 180 ringing, then theier implementation is illegal..
Hi Aokanlawon,
thanks for the Quik Response, can you please tell me what commands I use to disable the "PRACK" on my Router????
I'l wait for your reply...
voice service voip
sip
no rel1xx require "100rel"
Test again and send debug cccsip messages
Hi Aokanlawon,
I disable the " PRACK" using ( no rel1xx require "100rel") and made a TEST calls but still the calls are Disconencted.. Below is the debug cccsip messages I obtained.
SIP Call messages tracing is enabled
BZE-AGGR-RAS03#
BZE-AGGR-RAS03#
BZE-AGGR-RAS03#
Mar 26 23:59:51.595: Sent:
To: <912067343134>
Date: Tue, 26 Mar 2013 23:59:51 GMT
Call-ID: 151B99C4-95A811E2-AE7DAB8F-15D318CD@200.32.250.52
Supported: timer,100rel
Min-SE: 48000
Cisco-Guid: 354130372-2510819810-2927340431-366155981
CSeq: 101 INVITE
Max-Forwards: 6
Remote-Party-ID: <200.32.250.52>;party=calling;screen=no;privacy=off
Timestamp: 1364342391
Contact: <200.32.250.52:5060>
Expires: 180
Content-Length: 272200.32.250.52:5060>200.32.250.52>912067343134>200.32.250.52>
v=0
o=CiscoSystemsSIP-GW-UserAgent 756 3351 IN IP4 200.32.250.52
s=SIP Call
t=0 0
m=audio 18520 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Mar 26 23:59:51.651: Received:
SIP/2.0 100 Trying
To: <912067343134>;tag=gK0eccc9d0
CSeq: 101 INVITE
Content-Length: 0912067343134>200.32.250.52>
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Contact: <912067343134>
Content-Length: 257
Content-Type: application/sdp912067343134>912067343134>200.32.250.52>
v=0
o=Sonus_UAC 26164 19598 IN IP4 66.198.40.9
c=IN IP4 66.198.40.6
t=0 0
m=audio 20086 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
To: <912067343134>
CSeq: 101 CANCEL
Max-Forwards: 6
Timestamp: 1364342412
Mar 27 00:00:12.491: Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Mar 27 00:00:12.507: Received:
SIP/2.0 487 Request Terminated
CSeq: 101 INVITE
Mar 27 00:00:12.511: Sent:
Max-Forwards: 6
Content-Length: 0
CSeq: 101 ACK912067343134>200.32.250.52>
SIP/2.0 180 Ringing
Hi Aokanlawon,
Finally the calls are Terminating succesfully. It had to do with the "PRACK" as you mensioned earlier. I called the ITSP at fisrt they were requesting the "PRACK" but then they disable that option on thier end,and they Never Informed me, I went and disabled the Option on my side and the calls Terminating Succesfully, I think the ITSP did more changes on thier side becasue I have the same configuration, I was Using when I started the TEST..........
You Help me ALOT in Identifying the Problem ..thanks for evreything ,,Wish you the BEST......take care..
Danny
Danny,
Hi Aokanlawon,
Yes, calls are working without "PRACK"
Below is the configuration I used but I am sure the ITSP did some changes on thier side, becuase this is the same Configuration I was using when we started the SIP Trunk connectionit never work and then I ADD the "PRACK" which made calls termiante but get disconnected, and finaly at the END I had to remove the "PRACK" which Made the calls terminate Succesfully,,,,LACK of COMMUNICATION with the ITSP.. ..LOL.. and THANKS AGAIN for YOUR HELP......
Below is the COnfig I Am using,,,,,,
voice service voip
fax protocol pass-through g711alaw
h323
no ras brq
h245 caps mode restricted
sip
bind all source-interface FastEthernet0
description OUT_TATA_SONUS
preference 1
destination-pattern 912067343134
session protocol sipv2
session target ipv4:66.198.40.9:5060
dtmf-relay rtp-nte h245-alphanumeric
no vad
