12-09-2020 07:31 AM
Hi guys,
I have 2 SIP trunks to a SIP GSM gateway and a SIP TSP. Each one connected to an interface in the CME router.
I am running version 10.5 of CME.
My issue started once I configured the SIP trunk to the TSP.
Calls coming from the SIP GSM gateway are getting redirected to an internal extension but the voice is going to the SIP trunk.
As result audio coming from the GSM is not heard but audio from the CME is heard without an issue by whoever called from the GSM gateway.
We noticed that in the SIP message for some reason the internal extension comes with the IP address of the interface with the SIP trunk to the TSP.
Does anyone have an ideia what might be the cause of the issue?
12-09-2020 09:24 AM
I don't work on CME, but if it's the same as CUBE (and I think it might be) then you'll likely need to bind your interfaces to your dial-peers. Do you have commands on your dial-peers like "voice-class sip bind media" and "voice-class sip bind control"?
12-09-2020 10:09 AM
Also make sure you have correct routing for respective sip trunk destination servers.
