Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP calls on Gateway
silex
We have 2 gateways each has a max conn 25 command set on the ITSP dial-peer. Once 25 calls have been reached on a gateway, the 26th will failover if there are spare sessions on the other gateway. Is there a way that if the 51st call is attempted, that a message could be played to say the call cannot be made due to max lines being used? We are using CUCM 8.6 and H323 to gateway
Chris Deren
Not without some custom TCL script on the voice gateway.
Chris Deren
