SIP CUBE configurations- RTP IP address
rramlal
Hi team,
I am configuring a SIP gateway and the ITSP has a separate IP for RTP. So there is the sip server and rtp server. How can i set this up? is there a command for pointing to a separate rtp ip?
Ayodeji Okanlawon
You don't need to set this up from a sip perspective. All you need is configure your dial peer to point to the SIP signalling address.. (Sip server) provided by your ITSP.
You will only need to add the media address (rtp address) to the trust list on your CUBE
Please rate all useful posts
