SIP EXTENSIONS
kennedymacharia
I have a problem that has been bothering me for a while, I am using CME which is working fine with my sccp phones, I recently acquired cisco 9971 phones that I have registered with SIP. My problem is that the sip extensions cannot call the pstn. Please assist. here is my pstn dial peer
dial-peer voice 300 voip
 destination-pattern 9..........
 redirect ip2ip
 session protocol sipv2
 session target ipv4:10.0.0.11
 dtmf-relay rtp-nte
 no vad
Please check following two points;
1. Add bind command for SIP under dial-peer 300
2. Add codec (or voice-class codec) under dial-peer 300 as per your service provider requirement.
If doesn't resolve, please share the output of debug ccsip messages as asked by others too.
Vivek
6 Replies 6
Brandon Pierce
Level 4
Level 4
debug ccsip mess
debug voip ccapi inout
Going to need debugs from those two commands.  A dial-peer by itself isn't helpful without seeing why the PSTN or the gateway is kicking back the call.
hi,
Thank you for the reply I have done this debugs but there is no output. The sip phones are calling other extensions but cant call pstn. I have attached my whole config .
Vivek
hi Batra,
thank you it worked it was the codec. I knew I was missing something
Glad to know you get it resolved.
Vivek
Hi Kennedy,
Does Cisco 9971 able to call others phones?
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
