IP Telephony and Phones
Labels
Hi , I have got DX70 and DX80 working fine and registered to Call Manager 10.5.When first time  I powered ON, I skipped the wizard which has options like Jabber/Voicemail/ webex username .Now I want to configure Jabber  but I am not able to get the S...
Aman Soi by VIP Alumni
  • 4592 Views
  • 16 replies
Hi I recently install a SIP trunk to a UC540. Inbound call working fine.For outbound calls the ITSP requires me to insert country code and drop the leading zero for national/domestic calls. I currently use 9 for outside line access Has anyone ever cr...
I've been trying to get Visual Voicemail working on a version 11.0 system with no success.CUCM & Unity Connection are both the same version 11.0.1.20000-2.I've been through the process 3 times and still had no luck. Once the Unity end is done I can c...
billybjo1 by Level 3
  • 297 Views
  • 0 replies
Hi,    A,B are cisco ip phone ,registe at CUCM    A call B, B call forward to pstn or another voip gateway,   call pstn have to dial 0,xxxxxxx,call voip gateway dial xxxx.   I want to   if B call forward A to pstn (0,xxxxxx), I can send B phone numbe...
fly by Level 2
  • 890 Views
  • 13 replies
Hello everybody.My company has adquired recently a 2N Helios IP Force and Cisco 7975 IP Phones. We have sucessfully setup 2N helios and 7975 phone to receive and send audio calls using SIP protocol.But we have the problem that the video signal from 2...
fmoguer01 by Level 1
  • 1519 Views
  • 2 replies
Hello againI have here cisco cp-8945 he has ip from the DHCP server and Tftp ip but he always give mePhone not registered I dont know what the problem because when i connect the cisco ip phone simulator he working correctly but when i connect the rea...
Aolabi201 by Level 1
  • 572 Views
  • 1 replies
I have a pretty basic problem that has plagued me for some time that I assume there is a simple solution to but cannot find on my own.On a 9971 phone, when I am on a call, and I receive a call on the second line, I am unable to Divert this call to vo...
