10-31-2016 09:22 AM - edited 03-17-2019 08:32 AM
Dear All,
I got two SIP gateways (Pri & Sec) for PSTN calling and I have put them in a route group for redundancy.
Requirement:
when primary circuit run out of bandwidth I want all calls to route through secondary.
Do I need to configure anything here to achieve this task or is this a default behaviour of route group?
Thanks in advance
Syed
10-31-2016 09:39 AM
You will need to define how the "out of bandwidth" is tracked, here are some options for you:
https://supportforums.cisco.com/document/71326/call-admission-control-cac-implementation-cube
10-31-2016 09:43 AM
Hi Syed,
This is a default behaviour when I checked in my lab for CUCM v 10.
Check the following option below under Service parameters:
* Stop Routing on Out of Bandwidth Flag
Ensure this is set to False.
Hitesh
10-31-2016 09:49 AM
Thanks Chris & Hitesh.
I am running on CUCM 8.5.1. I shall try this and come to you.
Thanks again
10-31-2016 09:59 AM
Well, there is a distinction between out of bandwidth in CUCM from CUBE here, if you set CAC on CUCM then the only way to re-route would be via AAR which you do not want to for this type of failover, hence my suggestion to control it on CUBE.
