07-31-2018 09:38 PM - edited 03-18-2019 12:28 PM
Hi All,
We have a single 4331 router with 4 E1's and we want to use them for 4 different projects so that if any project makes outgoing call it should display the Pilot number of the E1 dedicated to that project.
It's a SIP gateway and from CUCM we have a single trunk to gateway. and we are using 9 as a prefix for outgoing calls.
Kindly help on this.
Regards..
Sudhir kumar
07-31-2018 10:33 PM
hi!
you have different ways for this:
1) use technical prefixes for outgouing calls. (you can create a CSS on CUCM, one for each project. and add a prefix with the route group). Then configure different dial-peers with translation profiles on router for that prefixes.
2) use dial-peer groups. if your projects using different dial-plan, you can create a inbound dial-peers with dial-peer group assined to it.
From Cisco docs:
08-01-2018 08:56 AM
