10-13-2011 06:53 AM - edited 03-16-2019 07:29 AM
I am configuring a SIP gateway on a 2911 router using a 4 port FXO card. I am new to SIP, can someone point me to a Cisco document on how to configure SIP? My call control is being done by a Verizon HIPC system.
Paul Wootton
10-17-2011 11:22 PM
HI Paul,
you can use the guide below:
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/chapter1.html
regards,
Trad
10-18-2011 01:11 AM
With all tihngs telco, you are reliant on their implementation of the standard. I would start with asking the provider if they have a sample config for how to configure your equipment to talk to theirs. Most providers can offer a sample config which will probably not be completely accurate but will at least get you started.
In the most basic configuration, you can do H323 dial-peers with "session protocol sipv2" and that can work.
The Gateways and Gatekeeper book from Cisco Press is a good resource for beginners and is now available on Google Books. there is also the CUBE configuration guide, but that is kind of advanced. http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_book/vb_book.html
Maybe I'm just kind of confused, but what are the FXO ports for?
10-18-2011 02:10 AM
- ahochau:
" In the most basic configuration, you can do H323 dial-peers with "session protocol sipv2" and that can work. "
once you add the session protocol as SIP then this is not H323 dial-peer it is SIP !
for th eoriginal poster you can use the bellow links as reference:
https://supportforums.cisco.com/docs/DOC-17616
hope this help
if helpful rate
10-18-2011 10:05 AM
I glad I worded it simply enough for you to understand the point I was trying to make.
