SIP Header Modification help
lordshawn
I just need help with the Diversion header for FORWARDED calls.
Using SIP profile 101, the original Diversion header is stripped and replaced with the prefix.
This is a single number reach scenario.
voice class sip-profiles 101
request INVITE sip-header Diversion remove
request INVITE sip-header P-Asserted-Identity remove
request INVITE sip-header SIP-Req-URI modify "sip:00..(.*)@(.*)" "sip:\1@\2"
request INVITE sip-header To modify "<sip:00..(.*)@(.*)>" "<sip:\1@\2>"
request INVITE sip-header From modify "<sip:00..(..........)(.*)@(.*)>(.*)" "<sip:\2@\3>\4"
request INVITE sip-header Contact modify "<sip:00..(..........)(.*)@(.*)>(.*)" "<sip:\2@\3>\4"
request INVITE sip-header Remote-Party-ID modify "Remote-Party-ID:(.*)<sip:00..(..........)(.*)@(.*)>(.*)" "Diversion: <sip:\2@\4>\5"
Feb 2 14:04:17.438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7139225156@11.666.17.2:5060 SIP/2.0
Via: SIP/2.0/TCP 11.666.0.11:5060;branch=z9hG4bK663decb94a30
From: "Varys" <sip:00012816762244135998@11.666.0.11>;tag=1092940~66c26381-b856-4eb2-822d-7bd4cab95e4a-68686082
To: <sip:7139225156@11.666.17.2>
Date: Thu, 02 Feb 2017 20:04:17 GMT
Call-ID: c57abc00-893190c1-4c486-b00f20a@11.666.0.11
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:11.666.0.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Cisco-Guid: 3313155072-0000065536-0000024509-0184611338
Session-Expires: 1800
Diversion: "Shawn McDermott" <sip:2816477000@11.666.0.11>;reason=follow-me;privacy=off;screen=yes
P-Asserted-Identity: "Varys" <sip:00012816762244135998@11.666.0.11>
Remote-Party-ID: "Varys" <sip:00012816762244135998@11.666.0.11>;party=calling;screen=yes;privacy=off
Contact: <sip:00012816762244135998@11.666.0.11:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
Feb 2 14:04:17.446: //229757/C57ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7139225156@11.666.16.107:5060 SIP/2.0
Via: SIP/2.0/UDP 11.666.17.2:5060;branch=z9hG4bK2D9BF87
From: "Varys" <sip:135998@11.666.17.2>;tag=37D79F04-18AE
To: <sip:7139225156@11.666.16.107>
Call-ID: 9C8D1421-E8B911E6-A3CCD62C-2C1285C5@11.666.17.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.4.2.T2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1486065857
Contact: <sip:135998@11.666.17.2:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Diversion: "Shawn McDermott"<sip:2816477000@11.666.17.2>;privacy=off;reason=follow-me;screen=yes
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 291
Diversion: <sip:2816762244@11.666.17.2>;party=calling;screen=yes;privacy=off
If I use SIP Profile 400 it removes the header and doesn’t rewrite it, which gives me a Unknown Number calling to my cell phone (Sip 101 atleast gave the Original called party).
voice class sip-profiles 400
Feb 2 14:08:12.721: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 11.666.0.11:5060;branch=z9hG4bK664735a69f031
From: "Varys" <sip:00012816762244135998@11.666.0.11>;tag=1093296~66c26381-b856-4eb2-822d-7bd4cab95e4a-68686171
Date: Thu, 02 Feb 2017 20:08:12 GMT
Call-ID: 518ce380-893191ac-4c4ec-b00f20a@11.666.0.11
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 1368187776-0000065536-0000024516-0184611338
Max-Forwards: 70
Content-Length: 0
Feb 2 14:08:12.729: //229820/518CE3800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 11.666.17.2:5060;branch=z9hG4bK2DA081789
Remote-Party-ID: "Varys" <sip:00012816762244135998@11.666.17.2>;party=calling;screen=yes;privacy=off
From: "Varys" <sip:135998@11.666.17.2>;tag=37DB3618-1C30
Call-ID: 28CA7541-E8BA11E6-A43CD62C-2C1285C5@11.666.17.2
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1486066092
Expires: 180
Max-Forwards: 69
Content-Length: 290
So that last line I need to have the remote party ID rewritten
Ayodeji Okanlawon
Looks like sip profile 400 is applied to the outbound dial-peer and not sip profile 101. You can add the sip profile configuration to strip the DIVERSION header to the profile 400.
Please rate all useful posts
What does this line do?
My main problem is 101 is writing a header i dont want.
This is replacing the RPID header with a diversion header with the values in the 2nd, 4th and 5th bracket of the remote-party-id (rpid)
