transcoder and MTP not registering in CUCM
SwathyEdayath
transcoder and MTP not registering in CUCM.
below is the configuration in gateway . transcoder configured as Cisco IOS Enhanced Media Termination Point in cucm (pvdm3).
checked access to port 2000 from our end .
sccp local GigabitEthernet0/1
sccp ccm 192.168.1.50 identifier 1 priority 1 version 7.0
sccp ccm 192.168.1.51 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register DHQKAFAXCODE
 associate profile 2 register DHQKAFAKCONF
 associate profile 3 register DHQKAFAKMTP
 switchover method immediate
 switchback method immediate
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 10
 associate application SCCP
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 2
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions hardware 2
 maximum sessions software 5
5 Replies 5
Suresh Hudda
Is conference has registered ? as you mentioned transcoder and mtp specifically.
Is IP voice media streaming application service is started on 192.168.1.50 or 192.168.1.51 ?
Have you configured same name of transcoder and mtp in CUCM which you have defined in router ?
Suresh
Make sure the DP assigned to the devices in CUCM is using the 192.168.1.50, 192.168.1.51 CM subs.
Validate the name of the resources in CUCM is what you entered on GW, what device type is the media built in CUCM as?
Try "no sccp", "sccp".
Thank you all . I have resolved the issue somehow with help of your comments .
Hi, How can I make two phones ringing for incoming pstn calls . currently only reception phone is ringing as per PLAR configured.
When you browse to these resources on CUCM what is the registration status. Also, share the output of 'show sccp'
