06-19-2018 06:15 PM - edited 03-17-2019 01:02 PM
Does the "From" field have to contain both user and host part in order to make a successful call?
For a particular intercom, when it call mobile the from field looks like this
sip:sip@domain.
Telco said since there is no number in user part, they do not know where to send traffic back, which may be the root cause for failing calls.
Thank you in advance.
06-20-2018 07:04 AM
06-20-2018 05:10 PM
Hi Nipun,
Thank you for the information.
Can you help to clarify one more question?
Attched is the flow sequence collected by Telco, I removed some of the digits of our CUBE external ip.
As you can see Telco sent OK message for the invitation and both parties exchanged SDP, does it mean Telco accept the call?
From the last OK message until the 487 message, there are 23 seconds without any information exchange, normally we should see ringing message sent from Telco, any idea why it did not happen.
06-21-2018 01:26 AM
