SIP: Internal Error (200, codec mismatch)
DJ2018
Hi Guys,
CUBE is a 2811 running on 151-4.M7
I am getting rusty. need some help to identify the problem.
Call Flow: IP Phone -> CME -> CUBE -> ITSP
This was a working call flow for around a month and stopped working.
I turned on
#debug ccsip messages
#debug voip ccapi inout
From basic troubleshooting done i could see that my CUBE is initiating the BYE message towards the provider.
right before sending the Bye i see below error.
000451: *Nov 10 09:28:24.055: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch):
I do not understand why i get this error.
This is the SDP sent by CME to CUBE in Invite.
c=IN IP4 192.168.1.1
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
This is the SDP sent by CUBE to provider in Invite.
m=audio 19578 RTP/AVP 18 101
c=IN IP4 10.1.1.1
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
This is the OK message received from Provider:
a=rtpmap:18 G729/8000/1 <-- not sure what is that extra /1
a=fmtp:101 0-15
a=ptime:20
a=maxptime:80
a=sendrecv
Then call disconnect with codec mismatch.
debug attached.
DJ
2 Accepted Solutions
Try to turn annex-b on cme and cube and see if it work. voice service voip
> sip > g729 anne
Ayodeji Okanlawon
The extra 1 indicates the encoding parameter used. It implies the number of audio channels used for transmission. The reason why you dont see this in most SIP messages is that it is an optional parameter if a single audio channel is used.
The issue you are having is indeed related to codec mismatch. According to the RFC, it states that there is no annexb attribute present in SDP, the default value assumed will be "YES" Hence in your case, since your CUBE is configured not to support annexb but your provider wants to do annexb, your call is failing.
You can either enable annexb using voice-class coded or use Mohammed's suggestion
Please rate all useful posts
> sip > g729 anne
thank you a lot, i solve my problem now .
IN TERMINAL MONITOR
%VOICE_IEC-3-GW SIP INTERNAL ERROR (200 CODEC MISMATCH).
With adding the commands :  voice service voip> sip > g729 anne
all is ok now.
Thank You
Ayodeji Okanlawon
This does not make any sense.
Call worked but SDP looks the same
Invite from CME-> CUBE [ i will verify the CME configuration ]
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:40
Invite from CUBE -> Provider
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
200 Ok from Provider to CUBE  <== (No annexb)
a=fmtp:101 0-15
a=ptime:20
a=maxptime:80
a=sendrecv
200 OK from CUBE to CME
t=0 0
m=audio 18840 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
Does this mean that Provider is talking to CUBE in Annexb=Yes and
CUBE to CME in Annexb=No ?
Does this consume transcoding?
DJ
