SIP IP Communicator
mightyking
Level 6
Level 6
Hi All,
I am having issues registering SIP IP Communicator with CUCM 10.5.
SCCP IP Communicator registers with no issue.
MK
Vaijanath Sonvane
Please check following settings:
  1. Check the device protocol is set to SIP.
  2. Configure correct device name configured in IP Communicator under Preferences >> Network. This device name should match with device name configured in CUCM.
  3. If you have "Enable Digest Authentication" enabled in Phone Security Profile, then make sure to associate digest user with IP Communicator Device.
VS
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
HI VS,
Thank you for replying. The issue was with TFTP server. But your reply deserves 5 points.
Thanks again,
MK
