06-14-2011 12:44 AM - edited 03-16-2019 05:26 AM
Hi All,
router: 2811, ios:c2800nm-ipvoicek9-mz.151-4.M.bin.
After router receives SIP INVITE with max-forward:0, tries to establish call connection. Does anybody know how to force router to send 483 Too many hops ?
Thanks for help.
Robert
06-16-2011 10:04 PM
Hi, Robert
what did you get from the router so far? please collect "debug ccsip all", and show running of the 2800
Rgds/Randy
06-21-2011 02:07 AM
06-21-2011 04:52 AM
Hi Robert,
It's working as expected.
As per Max-forwards of SIP...
Max-Forwards header limits the number of hops a request can make on the way to its destination. It consists of an integer that is decremented by one at each hop. If the Max-Forwards value reaches 0 before the request reaches its destination, it is rejected with a 483 (Too Many Hops) error response.
Pls note the underlined in the above statement so if the receiving router is in the transit toward the destination, then it will send 483 error. In this case, INVITE is reached to the final destination with "max-forwards:0" so it is setting up the call.
And also, as per Docwiki of Cisco...
Each proxy or gateway recipient of a request containing a Max-Forwards header field MUST check and update its value before forwarding the request. If the received value is zero (0), the recipient MUST NOT forward the request. Instead, for the OPTIONS and REGISTER methods, it MUST respond as the final recipient. For all other methods, the server returns 483 (too many hops).
Hope it helps...
Regards...
-Ashok.
06-21-2011 11:43 PM
Hi Ashok,
thanks for the info. But I do not thing it solves my problem.
I am working in R&D, so RFC, ITU, ETSI, etc are sources for me. So ...
When we look into RFC3261, the behaviour what to do if max-forward = 0 reach the destination is not cleary explained. But if we look at the definition of error answer 483 Too many hops
"The server received a request that contains a Max-Forwards (Section 20.22) header field with the value zero." and the definition of server:
"Server: A server is a network element that receives requests in order to service them and sends back responses to those requests. Examples of servers are proxies, user agent servers, redirect servers, and registrars."
We can assume that in our case router is a server, so should send 483 or there should be possibility to configure the behaviuor for this case. That is why i ask
I have checked also behaviour of CUCM for this case, and CUCM response with 483 (see attached trace, 10.15.20.1 is a CUCM). I thought that on all cisco devices the sip stack is implemented in the same way
Best regards,
Robert
06-22-2011 12:58 AM
Hi Robert,
In your capture, the CUCM needs to forward the INVITE to the destination number (1001) but observed "max-forwards" as 0. But,n earlier case, the INVITE was directly reached to the final destination (Router) and no need to forward to anybody. I think the devices will look at "max-forwards" parameter when they need to forward the requests.
Regards...
-Ashok.
06-22-2011 02:31 AM
Hi Ashok,
In my case, ruter is not destination. Router should send to PABX connected via PRI. Router is inside the path.
Robert
06-22-2011 02:56 AM
Hi Robert,
Ok then, I may be wrong but I think SIP Final destination is the router itself and Router will start TDM channel to the PBX. The SIP INVITE request is getting terminated at the router itself.
Regards...
-Ashok.
06-22-2011 03:01 AM
Hi Ashok,
The same like in CUCM. The sip invite is terminated and then CUCM start sccp to phone.
Robert
