01-29-2020 01:39 AM
Dear Community
I am having problems with multicast paging not working, when i call the pager no. phones accept the call, enable speaker and mute button, but no audio comes out. I have tried using Unicast which works perfectly.
I looked at this post: https://community.cisco.com/t5/ip-telephony-and-phones/7821-sip-to-sip-paging-issue-cme-10-5/td-p/2800936 but setting the CODEC does not fix my issue.
I am not sure where the problem is located, and i hope someone has an idea in which direction to troubleshoot this. Am I missing some multicast configuration on the router maybe?
Below i pasted all configurations from the ISR4321 running the system.
sh ver
Cisco IOS XE Software, Version 16.06.01
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 22-Jul-17 05:55 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ISR4321_R1 uptime is 34 minutes
Uptime for this control processor is 37 minutes
System returned to ROM by Reload Command at 09:41:41 UTC Wed Jan 29 2020
System restarted at 09:47:05 UTC Wed Jan 29 2020
System image file is "bootflash:isr4300-universalk9.16.06.01.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 uck9 Permanent uck9
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1797107K/6147K bytes of memory.
Processor board ID XXXXXXXXXXX
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
15263744K bytes of USB flash at usb0:.
0K bytes of WebUI ODM Files at webui:.
debug ephone paging
ISR4321_R1#
Jan 29 10:19:35.064: Paging-dn 20 sccp count=0 sip count=3
Jan 29 10:19:35.068: SkinnyBuildPagingList for DN 20
Jan 29 10:19:35.068: SkinnySetPagingList added DN 20 to list for DN 20
Jan 29 10:19:35.068: Paging Group List: 20 0 0 0 0 0 0 0 0 0
Jan 29 10:19:35.069: SkinnySetupPagingDnMulticast 239.0.1.20 20480 for DN 20
Jan 29 10:19:35.069: sip_multicast_page: for dn : 20
Jan 29 10:19:35.069: Found paging DN 20 on pool 1[40001]
Jan 29 10:19:35.069: Added interface GigabitEthernet0/0/0.100 to multicast list for DN 20
Jan 29 10:19:35.069: SipPagingPhoneReq for pool 1[40001] with multicast start
Jan 29 10:19:35.069: Found paging DN 20 on pool 2[40003]
Jan 29 10:19:35.069: SipPagingPhoneReq for pool 2[40003] with multicast start
Jan 29 10:19:35.070: Found paging DN 20 on pool 3[40002]
Jan 29 10:19:35.070: Added interface GigabitEthernet0/0/0 to multicast list for DN 20
Jan 29 10:19:35.070: SipPagingPhoneReq for pool 3[40002] with multicast start
Jan 29 10:19:35.070: Found paging DN 20 on pool 3[40004]
Jan 29 10:19:35.070: SipPagingPhoneReq for pool 3[40004] with multicast start
Jan 29 10:19:35.070: SkinnyBuildPagingList DN 20 for 2 targets
Jan 29 10:19:35.070: SkinnyStartPagingMedia for 2 targets for DN 20
ISR4321_R1#sh boot
BOOT variable = isr4300-universalk9.16.06.01.SPA.bin,1;
ISR4321_R1#sh telephony-service
CONFIG (Version=12.0)
Version 12.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Current configuration : 4837 bytes
! Last configuration change at 10:14:50 UTC Wed Jan 29 2020 by admin
! NVRAM config last updated at 10:15:28 UTC Wed Jan 29 2020 by admin
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname ISR4321_R1
boot-start-marker
boot system flash isr4300-universalk9.16.06.01.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
ip domain name system.local
ip dhcp pool DHCP_SCOPE
network 192.168.20.0 255.255.255.0
option 150 ip 192.168.20.1
domain-name system.local
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0.100
bind media source-interface GigabitEthernet0/0/0.100
registrar server
voice register global
mode cme
source-address 192.168.20.1 port 5060
max-dn 200
max-pool 50
load 7841 sip78xx.11-5-1-18.loads
authenticate register
authenticate realm all
timezone 27
time-format 24
tftp-path flash:
create profile sync 0013900030383261
auto-register
voice register dn 1
number 1001
name Allan
voice register dn 2
number 1002
name Dennis
voice register dn 3
number 1003
name Carlo
voice register pool 1
busy-trigger-per-button 2
id mac 0057.D2D1.6817
type 7841
number 1 dn 1
username 1001 password cisco
description Allan
codec g711ulaw
no vad
paging-dn 20
voice register pool 2
id mac 0057.D2D1.6A7E
type 7841
number 1 dn 2
username 1002 password cisco
description Dennis
codec g711ulaw
no vad
paging-dn 20
voice register pool 3
id mac 0057.D2D1.6D03
type 7841
number 1 dn 3
username 1003 password cisco
description Carlo
codec g711ulaw
no vad
paging-dn 20
no ip address
negotiation auto
encapsulation dot1Q 100
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0/1
ip address dhcp
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/CME-GUI-12.0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
tftp-server kern2.78xx.12-7-1-0001-393.sbn
tftp-server kern78xx.12-7-1-0001-393.sbn
tftp-server rootfs2.78xx.12-7-1-0001-393.sbn
tftp-server rootfs78xx.12-7-1-0001-393.sbn
tftp-server sboot2.78xx.12-7-1-0001-393.sbn
tftp-server sboot78xx.12-7-1-0001-393.sbn
tftp-server sip78xx.12-7-1-0001-393.loads
tftp-server kern2.78xx.11-5-1-18.sbn
tftp-server kern78xx.11-5-1-18.sbn
tftp-server rootfs2.78xx.11-5-1-18.sbn
tftp-server rootfs78xx.11-5-1-18.sbn
tftp-server sboot2.78xx.11-5-1-18.sbn
tftp-server sboot78xx.11-5-1-18.sbn
tftp-server sip78xx.11-5-1-18.loads
telephony-service
max-ephones 50
max-dn 200
ip source-address 192.168.20.1 port 2000
service phone backlightIdleTimeout 00:10
service phone displayOnWhenIncomingCall 1
service phone backlightOnTime 11:00
service phone backlightOnDuration 10:00
service phone backlightidleTimeout 00:01
service phone daysDisplayNotActive 1,2,3,4,5,6,7
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 29 2020 10:14:36
ephone-dn 20
number 2000
name PAGER
paging ip 239.0.1.20 port 20480
paging group 20
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
