04-14-2013 09:37 AM - edited 03-16-2019 04:47 PM
I have an 871 router and when I attempt to connect a SIP phone inside my network it says it registers correctly, and I can recieve calls, but unable to make any calls. Same phone same config on a dlink router works fine. The 871 apparently is blocking something but not sure what.
p_router#sh run
Building configuration...
Current configuration : 3982 bytes
version 12.4
no service pad
hostname p_router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.105.21.200 10.105.21.254
ip dhcp excluded-address 10.105.21.1 10.105.21.20
ip dhcp pool NETWORK
network 10.105.21.0 255.255.255.0
default-router 10.105.21.254
dns-server 10.105.21.2 10.105.21.3
no ip domain lookup
username admin privilege 15 secret 5 PasswordOmitted.
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 10.105.21.254 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.105.21.3 22 interface FastEthernet4 22
ip nat inside source static tcp 10.105.21.3 21 interface FastEthernet4 21
ip nat inside source static tcp 10.105.21.3 80 interface FastEthernet4 80
ip nat inside source static tcp 10.105.21.200 3389 interface FastEthernet4 3389
access-list 1 permit 10.105.21.0 0.0.0.255
access-list 23 permit any
access-list 100 remark WAN
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
login local
transport input ssh
scheduler max-task-time 5000
end
p_router#
04-15-2013 01:24 PM
where is your phone register, your config didn't include any voice configuration.
try to add "ip routing" and make sure you have the correct default route
Anas
please don't forget to rate the helpful posts
04-15-2013 02:26 PM
The phones is registered to a remote service. The 871 is just acting as a router the phone is not registered to it.
04-15-2013 02:44 PM
you need to add option 150 to the dhcp
option 150 ip CCM-IP
also make sure you can ping the ccm from vlan 1
ping ccm-ip source vlan 1
Anas
04-16-2013 07:05 AM
I am using a third party SIP provider and the phone is not a cisco phone. The only Cisco device is the 871. When I connect the phone to a home router that does not use option 150 the phone connects to the SIP provider and I am able to make calls. It does not work behind the 871.
