E1 R2 Inbound Calls
Leonardo Santana
Hello i have an SIP Gateway running IOS c2951-universalk9-mz.SPA.152-4.M1.bin
Outbound calls are working but inbound not, m connection with the PSTN is E1 R2
I received this error on debug vpm error:
Apr 11 21:00:32.203: [0/2/0:0(9), R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_0000]  -> ERROR: INVALID INPUT
I see the call on the gateway but it not ring on the phone the disconnect cause is 16
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
10 Replies 10
islam.kamal
Level 10
Level 10
Hello
I hope you are fine . As you know Cause No. 16 - normal call clearing.
This cause indicates that the call is being cleared because one of the users involved in the call has requested that the call be cleared. What it means:
This could be almost anything; it is the vaguest of the cause codes. The call comes down normally, but the reasons for it could be:
Bad username or password
Router's settings do not match what is expected by the remote end.
Telephone line problems.
Hung session on remote end
If your configuration is ok , may be some thing from ITSP when send digits to you when you receive an incoming call.
Thank you
please rate if this will help
Islam,
I don't think you understood the issue, this is E1 R2 circuit not SIP trunk, he is using SIP to control the GW. You might want to read the questions more carefully.
Leonardo,
Can you post "debug vpm signal" for this call? Are you seeing expected digits?  "Debug ccsip messages" and "debug voip dialpeer" would be helpful as well along with the config.
HTH,
Chris
Thank Chris for advise , i am sorry
No problem my friend, sorry if I came off to harsh, you have been doing superb job helping others on the forum :-)
Chris
Do not say that , you are completely true i did not read the question carefully. You are one of the leaders here , who i learn form him.
Thanks again
Thanks, lets know hope we can help Leonardo here with his little problem. E1 R2 circuits are fresh on my mind as I have been doing cutovers in Mexico with several of these over the last few weeks :-)
Chris
Hello
I will post the output of the debugs in a few minutes.
Leonardo Santana
Hey Chris
Follow the debus attached, and my inbound dial-peers below:
dial-peer voice 4000 pots
incoming called-number .T
direct-inward-dial
port 0/0/0:0
dial-peer voice 4001 voip
description -------------[dialplan-to-CCM-01]
preference 1
destination-pattern 7...
session protocol sipv2
session target ipv4: IP of CUCM PUB
voice-class codec 1
dtmf-relay rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax protocol pass-through g711ulaw
dial-peer voice 4002 voip
description -------------[dialplan-to-CCM-02]
preference 2
session target ipv4: IP of CUCM SUB
voice-class codec 1
dtmf-relay rtp-nte
We are using SIP to control the gateway.
In CUCM we have an SIP Trunk to this gateway, my link to PSTN is an E1 R2
Leonardo Santana
leonardo,   the initial error that you got in your initial post was:
which is on 0/2/0:9, your debug vpm info that you included was on 0/0/0:13  (are you hunting ports or is this a mistake?)
23:50:38.516: r2_reg_event_proc(0/0/0:0(13)) ADDR_INFO_COLLECTED (DNIS=7224, ANI=11966057981)<---------------------done digit collection
Apr 11 23:50:38.516: r2_reg_process_event: [0/0/0:0(13), R2_REG_COLLECTING, E_R2_REG_ADDR_COLLECTED(89)]
Apr 11 23:50:38.516: r2_reg_ic_addr_collected(0/0/0:0(13))htsp_switch_ind
Apr 11 23:50:38.624: htsp_dialing_done(0/0/0:0(13))
Apr 11 23:50:38.624: //-1/7222B3A08064/CCAPI/cc_api_call_setup_ind_common:
   Sub Called(TON=Unknown, NPI=Unknown, Data=, Length=154)
Apr 11 23:50:38.628: htsp_process_event: [0/0/0:0(13), R2_Q421_IC_WAIT_ANSWER, E_HTSP_SETUP_ACK]
Apr 11 23:50:38.628: r2_q421_ic_setup_ack(0/0/0:0(13)) E_HTSP_SETUP_ACK
Apr 11 23:50:38.628: r2_reg_switch(0/0/0:0(13))
Apr 11 23:50:38.628: r2_reg_process_event: [0/0/0:0(13), R2_REG_WAIT_FOR_SWITCH, E_R2_REG_SWITCH(96)]
Apr 11 23:50:38.628: r2_reg_ic_switched(0/0/0:0(13))
Apr 11 23:50:38.628: htsp_process_event: [0/0/0:0(13), R2_Q421_IC_WAIT_ANSWER, E_HTSP_PROCEEDING]
Apr 11 23:50:38.628: htsp_process_event: [0/0/0:0(13), R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_0000]
Apr 11 23:50:53.516: R2 Incoming Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_IN_WAIT_REMOTE_ALERT R2 Got Event R2_TONE_TIMER
Apr 11 23:50:53.516: R2_TONE_TIMER in r2_comp_wait_remote_alert
Apr 11 23:50:53.516: r2_reg_generate_digits(0/0/0:0(13)): Tx digit '#'     <----what is this???????
Apr 11 23:50:53.516: r2_reg_generate_digits(0/0/0:0(13)): Tx digit '4#'
Apr 11 23:50:53.516: R2 Incoming Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_IN_IDLE R2 Got Event R2_STOP
Apr 11 23:50:53.516: r2_reg_event_proc(0/0/0:0(13)) ABORT_DIGIT_COLLECT
Apr 11 23:50:53.516: htsp_process_event: [0/0/0:0(13), R2_Q421_IC_WAIT_ANSWER, E_R2_REG_ABORT_DIGIT_COLLECT]
Apr 11 23:50:53.740: htsp_process_event: [0/0/0:0(13), R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_1000]
Apr 11 23:50:53.740: r2_q421_ic_clr_fwd_idle(0/0/0:0(13)) Rx CLEAR FWD
Apr 11 23:50:53.740: r2_reg_channel_disconnected(0/0/0:0(13))   <------------------------------------------------------------disconnect
The Rx Clear FWD message indicates that the call is cleared by the calling party, as to what caused this I am not able to tell.
Please remember to rate useful posts, by clicking on the stars below.
Hello guys,
I found the cause and we solve this issue.
I test the SRST feature and the gateway as able to receive calls normally, i register again the IP Phones on CUCM  i collected the traces on CUCM and i see that the SIP Header of the gateway was with the IP of the firewall, we check with the security team and they configured an NAT from the netwoerk of this site to network where CUCM is located.
After they take took the Nat config the calls worked.
Thanks for the help.
Leonardo Santana
Leonardo Santana
