01-25-2016 04:51 AM - edited 03-18-2019 11:46 AM
Hi , i have a problem with my sip phone :
i have a 7940 and router 2800 and 1 sip phone 3CX 6
in this my configuration i can call to 3CX but i can not a call from 7940 to 3cx
please help me to figure out !!
Current configuration : 2791 bytes
! Last configuration change at 15:40:41 teh Mon Jan 25 2016
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$AIjw$q58644kSsCGwV9EBPqQlY.
no aaa new-model
clock timezone teh 3 0
clock calendar-valid
dot11 syslog
ip source-route
ip cef
ip dhcp pool voice
network 192.168.16.0 255.255.255.0
default-router 192.168.16.7
option 150 ip 192.168.16.7
no ipv6 cef
template 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server
voice register global
mode cme
source-address 192.168.16.7 port 5060
max-dn 3
max-pool 3
authenticate register
application 3cx
tftp-path flash:
create profile sync 0002956212552079
voice register dn 1
number 4000
allow watch
name 4000
label 4000
voice register dn 3
number 104
allow watch
name 104
label 104
voice register pool 1
id mac 001E.6850.781B
number 1 dn 1
dtmf-relay sip-notify
username 4000 password cisco
codec g711ulaw
voice register pool 2
number 2 dn 3
username 104 password cisco
codec g711ulaw
voice-card 0
codec complexity high
license udi pid CISCO2811 sn FHK0848F2CN
username cisco password 0 cisco
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 192.168.16.7 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.2.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
connection plar 1001
caller-id enable
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 1 pots
destination-pattern 2
dial-peer voice 29 voip
sip-ua
retry invite 3
retry register 3
timers register 150
telephony-service
max-ephones 42
max-dn 10
ip source-address 192.168.16.7 port 2000
load 7960-7940 0002956212552079
max-conferences 2 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 25 2016 15:22:45
ephone-dn 1
number 5020
name soroush afshari
ephone-dn 10
number 5010
name Mohammadreza shokri
ephone 1
no multicast-moh
mac-address 000D.6536.907C
keepalive 30 auxiliary 1
type 7940
button 1:1
line con 0
line aux 0
line vty 0 4
password kava123
login
transport input telnet
scheduler allocate 20000 1000
ntp server 192.168.16.1
end
Solved! Go to Solution.
01-30-2016 11:46 AM
01-30-2016 11:46 AM
Can you provide debug ccsip message output
01-30-2016 11:31 PM
thanx but there is another case for this
need to change a one command in configuration ;
"no Multicast-moh'
this command must be change to multicast-moh
01-30-2016 11:46 PM
Okay. Thanks for the info
