SIP Phone on Cisco UC500
wbourguibartic
I have a Cisco UC540 on which are registred Cisco IP Phones.
I configured a sip account to test SIP phones on UC, this is sip configuration :
voice register global
mode cme
source-address 192.168.10.10 port 5060
max-dn 20
max-pool 20
authenticate presence
authenticate register
authenticate realm 192.168.10.10
create profile sync 2783119853547512
voice register dn  1
number 900
call-forward b2bua busy 123
call-forward b2bua noan 123 timeout 20
allow watch
name Walid
label XXXXXX
mwi
voice register pool  1
id mac 0025.BC2B.71AD
number 1 dn 1
dtmf-relay sip-notify
username 900 password 900
codec g711ulaw
the SIP phone is registered successfully :
#show voice register pool all
Pool Tag 1
Config:
  Mac address is 0025.BC2B.71AD
  Number list 1 : DN 1
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Bria iPhone 1.2.6
  DTMF Relay is enabled, sip-notify
  Call Waiting is enabled
  DnD is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is not supported
  registration Call ID is 72ANTg2KU5MwZOAKatWNT-RsXNkjCtT9
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 900
contact IP address: 192.168.10.108 port 64995
Dialpeers created:
Dial-peers for Pool 1:
dial-peer voice 40001 voip
destination-pattern 900
session target ipv4:192.168.10.108:64995
session protocol sipv2
codec  g711ulaw bytes 160
  call-fwd-busy        123
  call-fwd-noan-timeou 20
  call-fwd-noan        123
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 1
  Total SIP phones registered: 1
  Total Registration Statistics
    Registration requests  : 5
    Registration success   : 5
    Registration failed    : 0
    unRegister requests    : 4
    unRegister success     : 4
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 13:25:35.991 CET Wed Jun 29 2011
    Last unregister request time : 13:25:48.467 CET Wed Jun 29 2011
    Register success time        : 13:25:35.991 CET Wed Jun 29 2011
    Unregister success time      : 13:25:48.468 CET Wed Jun 29 2011
But calls between SIP phones and skinny phones are failed. Outgoing calls from SIP phones failed also.
I joined an internal call (from sip to skinny) debug.
Thank you very much for help.
vandana
Would you please attach " debug ccsip all" and Debug voip ccapi inout along with "sh run".
here is show run and debug file.
I have faced with the same problem.
Without SIP trunk everithig is working fine. After configuring SIP trunk, using CCA, I can't make any kind of calls from SIP phones.
Rignt now I don't have UC500 for test purpose, but I will try to manualy configure SIP trunk, not through CCA.
If you find the solution , please shere it with us.
O
IdontNeedNick
I found the solution !!!
When you setup SIP trunk using CCA , in the configuration you can find tthe following lines
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
and
voice service voip
sip
sip-profiles 1000
The solution of the problem is :     no sip-profile 1000 !!!!
O
