How the calls are supposed to run between the sites (SIP, H323, POTS).
In addition to attached config, can you please perform a test call and share the following:
1. Calling/Called Number
2. Debug voice dialpeer from both routers
3. If you are using SIP, please share debug ccsip messages
4. If you are using H323, please share debug cch323 h225
5. If you are using POTS PRI please share debug isdn q931. If FXO, please share debug voice ccapi all
