SIP SRST 8961 stuck on "Phone Not Registering".
Paul Cobley
Trying to test SRST to a couple of 8961's [running sip8961.9-3-2-10] but they are stuck on "Phone Not Registering". The debug events show registration successful :-
*Apr 19 13:35:15.911: VOICE_REG_POOL: Register request for (8000351) from (192.168.2.17)
*Apr 19 13:35:15.911: VOICE_REG_POOL: Contact matches pool 1
*Apr 19 13:35:15.911: VOICE_REG_POOL: key(8000351) contact(192.168.2.17:5060) add to contact table
*Apr 19 13:35:15.911: VOICE_REG_POOL: key(8000351) exists in contact table
*Apr 19 13:35:15.911: VOICE_REG_POOL: contact(192.168.2.17) exists in contact table, ref updated
*Apr 19 13:35:15.911: VOICE_REG_POOL: key(192.168.2.17) contact(8000351) add to srst contact table
*Apr 19 13:35:15.911: VOICE_REG_POOL: key(192.168.2.17) exists in srst contact table, ref updated
*Apr 19 13:35:15.911: VOICE_REG_POOL: Created dial-peer entry of type 1
*Apr 19 13:35:15.911: VOICE_REG_POOL: Registration successful for 8000351, registration id is 6
TRU_UK_CUBE#sh sip-ua status registrar
Line          destination      expires(sec)  contact
transport     call-id
              peer
8000351       192.168.2.17     2066          192.168.2.17
UDP           64d814a5-2f3b10bf-763ff1ce-0680dbce@192.168.2.
              40001
8000351       192.168.2.17     2145          192.168.2.17
UDP           64d814a5-2f3b10e9-784d5746-2bf3a5eb@192.168.2.
              40001
8000351       192.168.2.17     2807          192.168.2.17
UDP           64d814a5-2f3b1122-6d1f6be2-5504228d@192.168.2.
              40001
8000351       192.168.2.17     2886          192.168.2.17
UDP           64d814a5-2f3b114c-14142dfb-3419cb5e@192.168.2.
              40001
8000351       192.168.2.17     3108          192.168.2.17
UDP           64d814a5-2f3b1176-42a4c265-3463ad6d@192.168.2.
              40001
8000351       192.168.2.17     529           192.168.2.17
UDP           64d814a5-2f3b11a8-269f5b0e-113002ec@192.168.2.
              40001
TRU_UK_CUBE#sh voice register global
CONFIG [Version=9.1]
  Version 9.1
  Mode is srst
  Max-pool is 500
  Max-dn is 500
  Outbound-proxy is enabled and will use global configured value
  Security Policy: DEVICE-DEFAULT
  Forced Authorization Code Refer is enabled
  timeout interdigit 10
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
  MWI unsolicited notify is disabled
  Active registrations  : 7
  Total SIP phones registered: 1
  Total Registration Statistics
    Registration requests  : 7
    Registration success   : 7
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : *13:36:35.255 UTC Fri Apr 19 2013
    Last unregister request time :
    Register success time        : *13:36:35.259 UTC Fri Apr 19 2013
    Unregister success time      :
The important bits of the config are here ......
voice service voip
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 600 min 60
max-dn 500
max-pool 500
voice register dn  1
number 8014141
preference 1
voice register dn  2
number 8000351
preference 1
voice register dn  3
number 8000352
preference 1
voice register pool  1
id network 192.168.2.0 mask 255.255.255.0
dtmf-relay rtp-nte cisco-rtp sip-notify
codec g711ulaw
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:192.168.2.254 expires 3600
sip-server ipv4:11.0.0.1
connection-reuse
So all looks good but the handset still shows the message 'Phone Not Registered'.
Just upgraded the IOS to c3900-universalk9-mz.SPA.152-4.M3.bin
Any ideas to get these handsets to register in SRST ?
TIA
Paul.
hi do you still have this issue or it is solved , please let me know .
If you debug ccsip messages, can you see the register attemptes?
Please capture the debugs si we can see what is exactly going on.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
