12-03-2013 05:10 AM - edited 03-16-2019 08:40 PM
we are facing a behavior with SIP third Party devices on cucm 8.6.2aSU3
The behavior is that in every call the device use the callmanager as MTP to place the call and the RTP stream is always through the callmanager.
We would like that the RTP goes directly between the devices as happens with Cisco IP Phones.
Bye
Giovanni
12-03-2013 05:54 AM
Maybe the two SIP devices do not have compatible codecs so they are going through an MTP to comply with the audio capabilities? You should try and check SDP message exchange between the two using RTMT Traces.
Also make sure that within the SIP Profile the flag "Media Termination Point Required" is not checked.
Ciao,
Francesco
12-03-2013 06:15 AM
we made some test and the problem is only in calls to PSTN.
internal calls works fine with RTP between endpoints.
The Voice Gateway is connected in H.323 with Callmanager.
Giovanni
12-03-2013 06:28 AM
Is the GW a Cisco Device? What codecs are allowed within the dial-peer?
12-03-2013 06:45 AM
Yes, a cisco 2921 with IOS: c2900-universalk9-mz.SPA.152-4.M2.bin
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
These codecs are applied in the dial peers.
Giovanni
12-03-2013 10:19 AM
Is -Media Termination Point Required -option checked in h323 gw in cucm?
12-03-2013 10:24 AM
no it is not checked.
I tried configuring a SIP trunk to the Voice Gateway and a Dedicated Route Pattern to my mobile number to make a test.
And the RTP streaming goes directly between the SIP third party device and the Voice Gateway.
The problem is if you have a customer with hundreds of H323 Voice Gateway is not so good to change all the architecture setting up SIP trunks in all sites.
Anyone is able to get direct RTP between the SIP third party device and the Voice Gateway using H323 protocol?
Thank you
Giovanni
12-03-2013 01:59 PM
The MTP is most probably being alocated due to a DTMF mismatch. The third party SIP phone is using Inband DTMF but an H.323 gateway can only to Out of band DTMF with the CUCM. Thus we need an MTP to achieve this.
Jagpreet
12-04-2013 12:36 AM
Hello Jagpreet,
thank you for the information.
So is it impossible to use third party with H323 gateway correctly?
Isn't there any workaround in your opinion?
Thank you.
Giovanni
