Avaya phones connected to Cisco switch is not getting DHCP leases and phones not working
gkchakravarthy
                   All,
The below is the configuration on our router and we are using Avaya phones on the network .
The phones are not receiving dhcp leases and not working ,can anybody suggest what is causing this issue.
Building configuration...
Current configuration : 7871 bytes
! Last configuration change at 13:34:44 UTC Thu Mar 21 2013 by phadmin
version 15.1
service password-encryption
hostname ESBRBARMPLS5MB
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
--More--                           !
ip dhcp excluded-address 192.168.5.1 192.168.5.5
ip dhcp excluded-address 172.25.18.1 172.25.18.50
ip dhcp excluded-address 172.25.19.1 172.25.19.20
ip dhcp excluded-address 192.168.5.199 192.168.5.254
ip dhcp pool guest
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
lease 24
ip dhcp pool LAN
network 172.25.18.0 255.255.255.0
dns-server 172.26.1.5 172.26.1.125
default-router 172.25.18.1
domain-name xxxxxx.com
netbios-name-server 172.26.1.125 172.26.2.22
option 242 ascii L2Q=1,L2QVLAN=60
lease 3
ip dhcp pool VOICE
network 172.25.19.0 255.255.255.0
default-router 172.25.19.1
option 242 ascii MCIPADD=172.25.19.4, MCPORT=1719, HTTPSRVR=172.25.19.5, VLANTEST=0
ip domain name xxxxxxx.com
ip name-server 172.xx.xx.xx
vtp interface gi0/0.1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.26 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description #Connected to Active LAN#
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/1.1
  encapsulation dot1Q 1 native
ip address 172.25.18.1 255.255.255.0
no ip route-cache
interface GigabitEthernet0/1.50
encapsulation dot1Q 50
ip address 192.168.5.1 255.255.255.0
ip access-group 51 out
no ip route-cache
interface GigabitEthernet0/1.60
description Voice Vlan
encapsulation dot1Q 60
ip address 172.25.19.1 255.255.255.0
no ip route-cache
interface GigabitEthernet0/2
ip address 10.1.100.2 255.255.255.252
duplex auto
speed auto
router bgp 65000
synchronization
bgp log-neighbor-changes
network 172.25.18.0 mask 255.255.255.0
network 172.25.19.0 mask 255.255.255.0
neighbor 192.168.0.25 remote-as xxxx
neighbor 192.168.0.25 soft-reconfiguration inbound
neighbor 192.168.0.25 prefix-list deny-route in
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.1.100.1
ip prefix-list deny-route seq 5 deny 0.0.0.0/0
ip prefix-list deny-route seq 10 permit 0.0.0.0/0 le 32
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 172.26.0.0 0.0.255.255
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 51 deny   172.16.0.0 0.15.255.255
access-list 51 deny   10.4.0.0 0.0.255.255
access-list 51 permit any
route-map guest_traffic permit 10
match ip address 51
set ip default next-hop 192.168.1.2
17 Replies 17
acampbell
Can we see the config from the switchports that phones are connected to.
Also the uplink port for the switch to this router.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Anas Abueideh
Level 9
Level 9
kindly find the below threads. I think they will help you
https://supportforums.cisco.com/message/325037#325037
https://supportforums.cisco.com/message/3529601#3529601
Anas
please rate if it is helpful
Hello Alex,
please find the below configuration of the switch where phones are connected and it is access switch connected to core with l3 capability  and then connected to router
Current configuration : 5404 bytes
version 12.2
no service pad
hostname xxxxxxx
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
vtp domain none
vtp mode transparent
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 50,60
switchport access vlan 60
switchport mode access
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
switchport mode trunk
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 172.25.18.10 255.255.255.0
ip default-gateway 17.25.18.1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login local
line vty 5 15
login
end
this is the configuration from core to router and there are 3 other switches in between core and the switch where phones are connected.
xxxxxT>en
Password:
xxxxxxT#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
xxxxx03         Gig 0/38          127               T    AIR-CAP35 Gig 0
xxxxx02         Gig 0/34          137               T    AIR-CAP35 Gig 0
xxxxP01         Gig 0/36          159               T    AIR-CAP35 Gig 0
Exxxxx     Gig 0/49          134              S I   WS-C3560G Gig 0/51
xxxx
                 Gig 0/1           164             R S I  CISCO2921 Gig 0/1.1
xxxxxxxxxxT#sh run int Gig 0/1
Current configuration : 123 bytes
description Router Gi0/1
end
Thanks Anas will check the documentation.
Are the phones connecting in the first instance, or loosing their lease when disconnected?
I am assuming that the DCHP option have been checked and the phones setting files checked as well?
Hi Chakravarthy,
Can u share the Avaya IP phone model ?
regds,
aman
Hi Aman,
Phone model is 9608
Chakra.
Hi James,
phones are sendind requests but router is not leasing the ip addresses.
Hi Chakravarthy,
Please refer the Avaya Links which say about Avaya 9608 IP phone Firmware and some info related to LLDP.
http://support.avaya.com/forums/showthread.php?t=1386
http://downloads.avaya.com/css/P8/documents/100092537
Please try speaking to Avaya as well.
regds,
aman
Thanks Aman ,will give a try.
I had this problem before when I deployed AVAYA IP Office and Phones with cisco switch This is what you should do:
  • AVAYA IP Phones recognize only LLDP protocol not CDP so just run LLDP globally switch#(config)lldp run
  • then check if w/ switch#show lldp neighbors.
  • After that it is a good practice to Enable the VLAN tag and ID on the AVAYA IP phones. then on the vlan interface point the DHCP server of AVAYA IP phones to the IP OFFICE with switch#(config-if)ip helper-address x.x.x.x
  • Also avaya IP phone is using option 66 (TFTP server name) not option 150 (TFTP server IP address) so the IP phones should resolve the TFTP server (IP OFFICE).
Thanks Nicolo for your reply.
but however we are using same configuration at the other remote office and it is working fine i checked all the switches in that n/w for lldp and it is not enabled.
Gopineni,
I have been looking at the 9608 phone.
http://downloads.avaya.com/css/P8/documents/100161759
I think the issue hereis related to the option 242 in your dhcp scope in the original posting
Can you try removing the setting and re-insrting without the VLANTEST option
ip dhcp pool VOICE
no option 242 ascii MCIPADD=172.25.19.4, MCPORT=1719, HTTPSRVR=172.25.19.5, VLANTEST=0
Looks like the phone is trying to tag an 802.1Q value.
You ports are all set set to access in vlan 60 so we do not
want any tagging.
Worth a try.
Alex.
