09-28-2015 03:19 AM - edited 03-17-2019 04:24 AM
Hi Everyone,
I have set a SIP trunk from a ITSP provider on Cisco 3825 router, It sas successfully registered with ITSP.
1) we can successfully made a call form internal network to PSTN.
2) But when trying to call from PSTN to internal network, IVR played but when we dialed the desired extension the ring continuous to go, hence the IP Phone rings but when anyone pick up there was no voice and that time the caller is continuously listening the ringing tone. IVR is ios based on Cisco router.
My call flow is as follows,
PSTN ==> SIP(ITSP) ==> H323(VG to CUCM) ==> SCCP(IP Phones)
Kindly Help me,
Solved! Go to Solution.
10-29-2015 03:47 AM
OK.
pleade do this..
voice service voip
sip
no outbound-proxy dns:multinet.pri:5083
no listen-port non-secure 5083
dial-peer voice 100 voip
description **** Outgoing Call to Multinet SIP Trunk ****
translation-profile outgoing remove_prefix
destination-pattern 0.T
session protocol sipv2
session target sip-server
session transport udp
voice-class codec 1
dtmf-relay rtp-nte sip-notify
no vad
voice service voip
sip
sip-ua
sip-server dns:multinet.pri:5083
Test again and send me the ff from your gateway
debug ccsip mess
debug voip ccapi inout
10-29-2015 04:40 AM
10-29-2015 05:02 AM
Ok. i dont see any sip messages in this call...
What is the calling and called number..
Can you attach your current configuration please.?
10-29-2015 05:08 AM
10-29-2015 05:46 AM
OK. This call didnt make it to the logs. I dont see anything about the call in those logs..
What we need to do now is this.. (ensure you do this when the gateway is not so busy)
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
debug ccsip all
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
Next..
dial-peer voice 110 voip
no shut
dial-peer voice 111 voip
no shut
do another test call and send the logs. include call details
10-29-2015 05:48 AM
Also please add this command back..
voice service voip
sip
localhost dns:multinet.pri:5083
10-29-2015 07:41 AM
Hi Ayodeji,
after adding local host command back, sip trunk is in working now, i have shifted some route patterns on sip trunk for testing, hope i will not hear any issue. further i will update you tomorrow.... thank you soo much for your help.. really really apreciated...
10-29-2015 07:46 AM
Glad to help. Dont forget to rate useful posts
10-29-2015 08:43 AM
OK Ayodeji... when i call from my internal network to any mobile number... mobile rings.. but if i cancel the call from mobile... call doesn't disconnect from the ip phone and it continuous ringing and then the call automatically take another path i.e PSTN to again ring the mobile phone and this continue untill all possible options finished..
10-29-2015 05:13 PM
OK.
Again please send me a debug ccsip message. include calling and called number. Is this the only issue you have now, Does call work okay through the sip trunk?
10-30-2015 01:19 PM
Hello, Actually I am facing one more issue, we have multiple branches all over the country, so the issue is when any branch try to transfer or make conference the call drops, the issue was that all branches are using g.729 to complete the call and the sip trunk to itsp is using g.711 and I don't have enough resources to configure transcoder so for now i changed the branhes codec to g711..
attached are the ccsip mesages for the call I have one ITSP sip trunk and two pri, so first call take itsp when call canceled from mobile phone it automatically takes another path and then third path..
callled number : 03122401592
calling number : 4199 (cipc)
10-30-2015 05:33 PM
Ahmed,
You will have to speak to your ITSP.
Two things you need to tell them..
1. Your ITSP is sending both 180 ringing and 183 session progress for ringing.
They need to send only one..
2. When you cancel the call, your ITSP needs to send "487 cancel" but they are sending 480 temporarily unavailable..
BURJ-VGW#
290888: Oct 31 00:42:11.362: //509749/4CE6AD800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 10.99.3.102:5060;branch=z9hG4bK4852E22BA
To: <sip:03122401592@multinet.pri>;tag=J*9kWWNVOV
Call-ID: 23D62F72-7E7511E5-B5549F63-3301D68D@multinet.pri:5083
CSeq: 102 INVITE
Timestamp: 1446234128
Supported: timer
Allow: INVITE,ACK,CANCEL,BYE,INFO,REGISTER,NOTIFY
Contact: <sip:03122401592@125.209.93.196:5083;transport=udp>
Content-Length: 0
User-Agent: TELES.C5/5.0.7.4
Allow-Events: talk
290889: Oct 31 00:42:11.366: //509748/4CE6AD800000/SIP/Msg/ccsipDisplayMsg:
Sent:
BURJ-VGW#SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 172.20.11.11:5060;branch=z9hG4bK45686b35738e
From: <sip:4199@172.20.11.11>;tag=13878~18d2dfe6-ba54-48c4-b16e-0053a74e5282-43901612
To: <sip:903122401592@172.20.11.50>;tag=9700FABC-987
Date: Fri, 30 Oct 2015 19:42:08 GMT
Call-ID: 4ce6ad80-6331c810-2350-b0b14ac@172.20.11.11
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: kpml, telephone-event
Remote-Party-ID: <sip:03122401592@multinet.pri:5083>;party=called;screen=no;privacy=off
Contact: <sip:903122401592@172.20.11.50:5060>
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
BURJ-VGW#
290890: Oct 31 00:42:14.922: //509749/4CE6AD800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
CSeq: 102 INVITE
Supported: timer
Content-Length: 0
Allow-Events: talk
290891: Oct 31 00:42:14.926: //509748/4CE6AD800000/SIP/Msg/ccsipDisplayMsg:
Sent:
BURJ-VGW#SIP/2.0 183 Session Progress
CSeq: 101 INVITE
Content-Length: 0
BURJ-VGW#
290892: Oct 31 00:42:19.646: //509749/4CE6AD800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 480 Temporarily Unavailable
CSeq: 102 INVITE
Supported: timer
Contact: <sip:125.209.122.194:5083>
Content-Length: 0
Allow-Events: talk
Reason: Q.850;cause=31;text="Normal, unspecified"
This is the cause of the issue you see. So please escalate to your ITSP. They have not implemented their SIP solution correctly
11-01-2015 09:49 PM
But I cannot understand that this is only happening when I configured a sip trunk between CUCM and Voice Gateway before that when I was using H.323 gateway this was not happening. further I don't understand how ITSP can control my gateway as when the caller disconnect the call how ITSP send to take another PRI which is POTS to reach the destination. I think the issue is with our configuration.
these all are my opinions.
11-02-2015 03:18 AM
Well....
SIP and H323 are totally different protocols and they operate differently. SIP to SIP and SIP to H323 is a different game entirely.
My opinion is what I have already mentioned to you. Its up to you how you want to proceed with it. I could be wrong, but I can only tell you what I see in the logs.
Good luck with it.
11-02-2015 03:37 AM
Hi Ayodeji,
I am not an expert though I am only telling you my opinion, I have one more setup with BE6K, the same issue is coming there also all the config are up to the mark and that ITSP is different than this, I am only asking if there is any option in CUCM so from where we can tune the SIP trunk and It can be resolved, one thing I am not getting is the call go through E1 line and the third one is another E! PRI, now I am only asking if this is possible that ITSP message 183 can cause rerouting of call through another path? Thank you for all your precious time in solving my issue..
