04-21-2013 07:27 AM - edited 03-16-2019 04:55 PM
I'm not able to transfer a call from a SIP phone to another phone.For testing I use the Eyebeam Client, but I recognized the problem with other SIP devices too(SPAxxx).
I set up a light configuration in the lab with two SCCP phones and one SIP phone. Trying to transfer a call from the SCCP->SIP phone to the other SCCP phone. But everytime I'm getting a busy signal and all calls are dropped.
If I initiate the two calls from the SIP phone and connect the this two calls everything is fine, conferencing with all three, too.
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 10.0.16.1 port 5060
max-dn 56
max-pool 14
authenticate register
tftp-path flash:
create profile sync 0000315004002712
voice register dn 2
number 35
name TEST-PC
label TEST-PC
voice register pool 3
id mac F0DE.F1D1.CBB5
number 1 dn 2
dtmf-relay sip-notify
username pc_test password test_pc
codec g711ulaw
best regards
Christian
05-01-2013 01:08 PM
i usually do this. After the first call is connected I put the first call on hold and start the 2nd call. Then I press the xfer button on x-lite/eyebeam(which result in holding the 2nd call) and after that I press the line with which I want connect the call.
This problem occurs as I tried to transfer with a SPA SIP Phone on my UC500, for better testing I moved to the Softphone SIP Clients. I already simulated this problem with a 2811 and there occurs the same problem in a complety new lab without any other configuration or endpoint.
The mysterious thing is that a blind-transfer works.
regards
Christian
