05-30-2018 01:04 PM - edited 03-17-2019 12:55 PM
I have a "chatch 22".
Scenario:
CUCM 12.0 and UCCX 11.6
Incoming calls don't hear MOH, for the UCCX queue time, unless I enable "Media Termination Point Required".
When I enable the use of MTP, all outgoing calls fail with busy.
The PSTN are trough a Interoute SIP trunk, terminated on a Cisco CUBE-SP ASR1004.
Just floating this to hear if anyone have encountered a ,similar problem.
MOH works fine, when I put an external on hold from a IP-phone(8851).
05-30-2018 01:14 PM
05-30-2018 02:56 PM
Setting was "disabled"
Change to "mandatory" doesn't change the behavoir.
Calls work, but no MOH when calls are queued on the UCCX.
05-30-2018 03:01 PM
09-13-2019 12:42 PM
Were you able to resolve this issue? We are experiencing the exact same issue.
09-16-2019 10:41 AM
Ajlal,
You have the MOH selected in the Call Control on UCCX? That should have resolved the previous issue that you posted on.
Jason
09-17-2019 11:27 AM
Yes, the MOH source is selected for both User and Network hold in the call control groups in UCCX. Still, no music is heard.
