sip trunk between mitel 3300 and Cisco call manager 8.6
carl_townshend
Hi All
I have a sip trunk between my 2 systems, call manager ver 8.6 and a mitel 3300 pbx
it seems when we dial from the cisco to the Mitel, the calls dont always work, it seems to just show the number and not do anything, then the next time I try it works!
Are there any special settings between the 2 I should be made aware of, timers etc ?
cheers
Aaron Harrison
You'll need to take a look at the signalling exchange between the two devices in order to diagnose this.
Either set CUCm tracing to detailed and pull them, or use 'utils network capture host ip x.x.x.x' where x.x.x.x is your Mitel IP on the CUCM CLI to capture the signalling in wireshark format.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Jaime Valencia
Have you looked at the Cisco Interoperability Portal to see if there's something similar to your scenario??
java
if this helps, please rate
