03-26-2015 08:30 AM - edited 03-18-2019 11:29 AM
Hi guys,
Pretty sure I followed all instructions here http://tinyurl.com/oq5hgn7 but when it comes to the test, I have calls from Avaya IPO to CUCM 9 working great but calls from CUCM 9 to Avaya IP Office don't work.
Have someone experienced it before?
Solved! Go to Solution.
02-12-2016 12:12 AM
I am facing the same issue configuring a Sip trunk from call manager to avaya ip office but invite send from CUCM but not received at Avaya..logs of cucm is given below..Can you help from AVAYA side.
15:45:11.696 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 192.168.63.76 on port 50818 index 7072 with 1421 bytes:
[148891,NET]
INVITE sip:2016@192.168.33.4;user=phone SIP/2.0
Via: SIP/2.0/TCP 192.168.63.76:50818;branch=z9hG4bK07fa24ad
From: "2810" <sip:2810@192.168.33.4>;tag=dceb94cefeff00067f847817-06223b9d
To: <sip:2016@192.168.33.4>
Call-ID: dceb94ce-feff0004-39bbef38-0882aa54@192.168.63.76
Max-Forwards: 70
Date: Thu, 11 Feb 2016 10:45:10 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7841/10.3.1
Contact: <sip:c5208caa-3385-765c-de1b-5871c78c9017@192.168.63.76:50818;transport=tcp>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "2810" <sip:2810@192.168.33.4>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 351
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 15185 0 IN IP4 192.168.63.76
s=SIP Call
t=0 0
m=audio 22018 RTP/AVP 9 0 8 116 18 101
c=IN IP4 192.168.63.76
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
|CallingPartyNumber=2810
|DialingPartition=
|DialingPattern=201X
|FullyQualifiedCalledPartyNumber=2016
15:45:11.715 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 192.168.39.30 on port 5060 index 7073
[148893,NET]
INVITE sip:2016@192.168.39.30:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.33.4:5060;branch=z9hG4bKfd782ca618
From: <sip:2810@192.168.33.4>;tag=49391~0724933f-834e-40ea-a65f-5a5d274fd9df-46003885
To: <sip:2016@192.168.39.30>
Date: Thu, 11 Feb 2016 10:45:11 GMT
Call-ID: 85089b00-6bc16637-46-421a8c0@192.168.33.4
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 2231933696-0000065536-0000000002-0069314752
Session-Expires: 1800
P-Asserted-Identity: <sip:2810@192.168.33.4>
Remote-Party-ID: <sip:2810@192.168.33.4>;party=calling;screen=yes;privacy=off
Contact: <sip:2810@192.168.33.4:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
02-12-2016 12:51 AM
Hi Nadeem,
If you can not figure out from Avaya side what is the issue, only option from CUCM side is to enable early offer (under SIP profile) in CUCM and see how it goes.
- Vivek
02-12-2016 01:00 AM
If the INVITE is not seen at Avaya, then you have a different issue here.
You need to check network connectivity first. Is there a firewall between CUCM and Avaya?
02-12-2016 01:30 AM
Hi D, IMO there should not be network issue since INVITE is sent using TCP and if we can see INVITE in CUCM logs, that means TCP connection to Avaya has been established successfully which indicates that there should not be any routing related issue. Isn't it?
- Vivek
02-12-2016 01:47 AM
Yes that is correct, since CUCM already establish a TCP connection before sending the INVITE. I didn't check what transport protocol it was using..Thanks (+5)
However if the INVITE doesn't arrive at Avaya, then it could still be a network issue such as firewall etc.
02-12-2016 02:49 AM
Hi D, I got to know from one of the source (I can not validate his information) that if Avaya IPO receives INVITE without SDP offer, IPO SIP stack straight away ignores that message and doesn't give any event to application, hence logs might not be generated for the same.
Anyway, let see how the issue reporter responds further on this.
- Vivek
02-15-2016 06:36 AM
Dear Vivek,
Could you please confirm that in the above logs SDP invite along with SIP early offer generated or not??
