SIP TRUNK down
israel.castillo
Hi there
I am concern that I have a sip trunk to some avaya PBX (somewhere else), they point their SIP Trunk to the ip address of my subscriber, we had to power down my PUB, and my Sip trunk came down as well, I thought that my SIP trunk was going to be up because it was pointing to my sub and not my PUB and because our database replication,  what could be some possible reasons that my SIP trunk came down?  is it just because I turn off my PUB? Thanks.
6 Replies 6
Ratheesh Kumar
Hi there
Just curious to know whats your DB replication says ?
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
From CLI it says
match   Yes     (2) PUB Setup Completed
match   Yes     (2) Setup Completed
From SYSTEM REPORTS
System Reports
X.X.X.X 603 2 - good
X.X.X.X
603 2 - good
X.X.X.X
603 2 - good
Hi there
Your DB looks good. Can you try checking the "Run On All Active Unified CM Nodes" on SIP Trunk and test the failover
Hope this Helps
Cheers
Rath!
Yes it is checked the
"Run On All Active Unified CM Nodes" in SIP TRUNK,
Hi there
When Pub is down can you check the status of your Trunk. Try to do a reset and then try incoming/outgoing calls Also could you verify the configurations, especially the SIP trunk setup between Cisco and Avaya with this document.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/avaya-app-note-6-3.pdf
Hope this Helps
Cheers
Rath!
Thanks very much
I will check the document, so, in other words my Sip Trunk should stay up and there is no reason that went down, correct? I will keep searching for this.
