SIP trunk from CUBE without auth\reg
sSiDs
Hi team! after long time struggling with dropped sip-ua registration authentication, our voice ISP advise to create "straight" trunk without auth...but with "binding over our public IP"
actually, i don't now how to to do it...where and what needs to be changed.
below is out dial-peer for CUCM and Lync and outside calls
dial-peer voice 1 voip
 description ***outbound NATIONAL***
 translation-profile outgoing calerid
 destination-pattern 8[2-9].........
 progress_ind setup enable 3
 session protocol sipv2
 session target sip-server
 session transport udp
 voice-class codec 1
 voice-class sip profiles 1
 voice-class sip bind control source-interface FastEthernet0/1
 voice-class sip bind media source-interface FastEthernet0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 101 voip
 description ***to->CUCM***
 destination-pattern [1,2]...
 session target ipv4:10.110.240.10
 voice-class codec 1
 voice-class sip bind control source-interface FastEthernet0/0.8
 voice-class sip bind media source-interface FastEthernet0/0.8
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2000 voip
 description **Incoming Call from SIP Trunk**
 service sip_ivr
 destination-pattern 1003
 incoming called-number 111111
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 102 voip
 description System-Incoming-Dial-Peer
 translation-profile incoming calerid
 answer-address 749511111111
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2 voip
 description ***outbound INTERNATIONAL***
 destination-pattern 810.T
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3 voip
 destination-pattern 0[1-3]
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 1199 pots
 destination-pattern 1199
 port 0/3/0
 no sip-register
dial-peer voice 2001 voip
 description 8-800-Incoming-Dial-Peer
 translation-profile incoming 88
 incoming called-number 222222
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 5000 voip
 tone ringback alert-no-PI
 description ***Outgoing Call to LYNC***
 translation-profile outgoing 5000
 destination-pattern 5...
 rtp payload-type comfort-noise 13
 session target ipv4:10.110.1.32:5068
 session transport tcp
 voice-class codec 1
 voice-class sip block 183 sdp present
 voice-class sip bind control source-interface FastEthernet0/0.10
 voice-class sip bind media source-interface FastEthernet0/0.10
 dtmf-relay rtp-nte
 fax protocol none
 no vad
dial-peer voice 5001 voip
 description ***Incoming Call from LYNC***
 translation-profile incoming Lync_OUT
 incoming called-number +5...$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
num-exp 9 1199
gateway
 timer receive-rtp 1200
R2c2801#sh run | s sip-ua
sip-ua
credentials username 111111 password 7 xxxxxxx realm voip.voiceisp.com
credentials username 222222 password 7 xxxxxxx realm asterisk
authentication username 111111 password 7 xxxxxxx realm REGISTRAR
authentication username 222222 password 7 xxxxxxx realm asterisk
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 5
registrar 1 dns:voip.voiceisp.com:9060 expires 3600
registrar 2 ipv4:10.10.10.1:9060 expires 3600
sip-server ipv4:10.10.10.2:9060
no suspend-resume
host-registrar
permit hostname dns:voip.voiceisp.com
Hi Sid,
If your SIP ISP do not need any authentication, then you could remove sip-ua configuration and directly point all the outbound dial-peers to the ITSP IP address instead of using " session target sip-server " as in the below dial-peer:
session target ipv4:195.211.120.9
voice-class codec 1
dtmf-relay rtp-nte
no vad
Also make sure that these dial-peers are bound to FastEthernet0/1 which is used for accessing the outside network.
Rajan
8 Replies 8
sSiDs
forgot to add voice service voip settings
voice service voip
ip address trusted list
ipv4 195.111.1.234 //- voice ISP IP address
ipv4 192.168.1.181
ipv4 192.168.1.0 255.255.255.0
ipv4 10.110.240.0 255.255.255.0 //-local voip netwotk for phones and CUCM
address-hiding
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
header-passing
registrar server expires max 3600 min 120
asserted-id pai
midcall-signaling passthru
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class sip-profiles 1
request INVITE sip-header Min-SE modify "1800" "6000"
Hello Sid, they are several approaches to this you can take. If you are just looking to bind the traffic to your public IP, all you have to do is any traffic you are sending to session target sip-server, you would have to change the binding to go out whatever interface your public IP address is connected to. So for example change the underlined below:
another option would be to create a Voice class SIP profile and modify the from address to be that of the public IP.
Also remember that you would have to take of the sip-ua authentication since thats now want the ITSP would want.
 voice-class codec 1
 voice-class sip bind control source-interface FastEthernet0/1 (Change to the interface of the public IP)
 voice-class sip bind media source-interface FastEthernet0/1 (Change to the interface of the public IP)
 dtmf-relay rtp-nte
 no vad
Could you please explain more detailed?
Does it mean what Voice ISP asked? "straight trunk" without SIP-UA
CUCM IP is 10.110.240.10
VoiceISP IP is 195.211.120.9
so I need to run "no SIP-UA"
and which dial-peer-voice need to be re-configued?
all of outgoing?
 my public interface is F0/1
FastEthernet0/1
ip address 193.106.XX.XXX 255.255.255.0
ip access-group ANTISPOOFING in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no mop enabled
no ip address
speed 100
full-duplex
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 172.16.2.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
description ***VOICE***
encapsulation dot1Q 8
ip address 10.110.240.254 255.255.255.0
ip helper-address 10.110.1.22
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
encapsulation dot1Q 10
ip address 10.110.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
Hi Sid,
voice-class codec 1
dtmf-relay rtp-nte
no vad
Rajan
devils_advocate
Level 7
Level 7
Presumably Fa0/1 has your Public IP?
Do you just have a single SIP provider or are there others?
Your config towards the ISTP is pointing at the following:
Is that the IP of your SIP provider?
sorry for late reply and necro-posting)
10.10.10.2 it is ISP PBX address
fa0/1 has public i.e. 12.123.432.12
R0g22
You are still facing this issue after 2 years ?
no. now everything is OK.
