Sip Trunk - No audio - STREAM_DEAD
Hi all
Have a little issue with a SIP-trunk from Optimum connected via CUBE to a Cisco CUCM 8.6.2
Callflow: Provider SIP -> CUBE -> SIP -> CUCM -> SCCP phone
When inbound call is answered on the phone there is no audio either way. The odd part is when I do Show sip call the call leg between the provider and CUBE the status is STREAM_DEAD
Outbound call no issues.
Attached is debug, status and config
Any idea why?
The trunk has been working, until I was testing some DTMF from a 9951.. but cannot find out what is the issue..
Hello Martin,
when the inbound call is answered by phone, the CUCM sends 200 OK to CUBE.
*Jan 24 21:49:36.523: //38/3BE4116F8047/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.102.61.10:5060;branch=z9hG4bK16192A
From: "Name Unavailabl" <00045XXXXXX>;tag=265B68-B37
To: <>;tag=42094~b6d41696-648e-4f33-875e-543830787a17-25000868
Date: Fri, 24 Jan 2014 21:59:00 GMT
Call-ID: 3BE4AD97-847811E3-804DC245-95567DD5@10.102.61.10
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence, kpml
Supported: replaces
Call-Info: <10.2.1.51:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires:  14400;refresher=uas
Require:  timer
Contact: <>
Content-Type: application/sdp
Content-Length: 233
v=0
o=CiscoSystemsCCM-SIP 42094 1 IN IP4 10.2.1.51
s=SIP Call
c=IN IP4 10.102.61.10 ---> IP address to receive the RTP Stream (Phone's IP address)
b=TIAS:64000
b=AS:64
t=0 0
m=audio 16422 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000 ---> G711 U-law codec
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
However when the CUBE sends back the 200 OK to ITSP, it replies with IP address 0.0.0.0
*Jan 24 21:49:36.527: //37/3BE4116F8047/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.10.100.1:5060;branch=z9hG4bK302578409
From: "Name Unavailabl" <45XXXXXX>;tag=B9x%AG6dn7LmjNB0I3731E9A37f49ed4
To: ;tag=265BE8-1236
Date: Fri, 24 Jan 2014 21:49:28 GMT
Call-ID: 2075305078@10.10.100.1
CSeq: 1138 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <>;party=called;screen=no;privacy=off
Contact:
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-15.4.1.T
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 224
v=0
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:64000
b=AS:64
t=0 0
m=audio 0 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
>> so your CUBE is not responding to ITSP with correct IP address. it could be issue with media interface binding.
could you please post your cube config?
Please rate all the useful posts
//Suresh Please rate all the useful posts.
good observation, thanks.
Have been through the config, but should be fine.. Could it be that the interface the outbound dialpeer is bound to is DHCP?
Attached is the config... forgot it in the first post..
Hello Martin,
Yes, you are right. There is no static ip configured in the interface bound towards provider.
interface GigabitEthernet0/1
ip address dhcp
could you please try configuring an ip address to this ip address ensure it has proper routing towards other interfaces?
you may refer the below URL on how media & signaling binding works.
CUBE SIP Media and Signalling Binding to an Interface
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2013/04/04/cube-sip-media-and-signalling-binding-to-an-interface
//Suresh
