05-12-2011 04:17 PM - edited 03-16-2019 04:57 AM
For the life of me I cannot figure out why my sip trunk stopped working. If I look at the debugs these are the errors that I keep getting:
2811voice#REGISTER sip:did.voip.les.net:5060 SIP/2.0
Via: SIP/2.0/UDP 216.88.54.55:5060;branch=z9hG4bK18A1C84
From: <sip:2279854920@did.voip.les.net>;tag=3197250-C7F
To: <sip:2279854920@did.voip.les.net>
Date: Thu, 12 May 2011 17:53:13 GMT
Call-ID: 86135A3E-7BF711E0-8003DD75-791FFF66
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1305222793
CSeq: 2 REGISTER
Contact: <sip:2279854920@216.88.54.55:5060>
Expires: 200
Supported: path
Content-Length: 0
2811voice#
047832: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/act_sent_register_wait_100: act_sent_regist
er_wait_100: Out of retries
047833: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDecrementOverloadCount: Count:Local 0 G
lobal 0
047834: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code
Class 4xx Method Code 100 received for REGISTER
047835: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_free_rcb: Freeing rcb [0x4
AE6F5E4]
047836: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTE
R:: registrar 0 DNS resolved addr reset
047837: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/ccsip_api_register_result_ind: SIP Registra
tion Retries Exhausted
047838: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIRegPthruProcessResponse: Processing re
sponse w/ resp code == 408
047839: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetRPCBFromRCB: Retreiving RCB [0x4ACC0
400] from RPCB [0x0]
047840: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPC
B
047841: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartRCBTimer: Starting timer fo
r pattern 2279854920 for 120 seconds
047842: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key
=[396] removed.
047843: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting f
rom UAC table.
047844: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from tab
le. ccb=0x4A5EC5E8 key=86135A3E-7BF711E0-8003DD75-791FFF66
047845: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 eve
nts on the internal queue that are going to be free'd
047846: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profil
es Freed
2811voice#
047847: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/ccsip_offer_ans_delete:
047848: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/ccsip_iwf_delete:
047849: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4A5EC5E8
2811voice#show sip-ua register status
Line peer expires(sec) registered P-Associ-URI
2279854920 -1 114 no
Any ideas on why this could be happening? I was running version 15.1(3)M and upgraded to 15.1(4)M, but still the problem persists.
Dan.
05-12-2011 05:30 PM
are you using DNS to resolve the SIP SBC host name? Did IP address change?
408 usually means request timeout.
sipSPIRegPthruProcessResponse: Processing response w/ resp code == 408
05-12-2011 05:38 PM
Yes, I am using dns, and it was working....
So I just changed everything from dns:did.voip.les.net to ipv4:64.34.181.47, and I still have the same error messages.
Dan.
05-12-2011 05:52 PM
No changes, then the provider changes something. Maybe upgraded their cisco router from 12.4.x to 15.1.3 and forgot to trust your network .
Do you want to post your redacted config so the forum can review?
mike
05-12-2011 05:54 PM
BTW I assume that SBC address is in your IP trust list?
mike
05-12-2011 05:55 PM
No changes on my end happened....
voice service voip
ip address trusted list
ipv4 10.1.1.11 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 250 min 200
sip-ua
credentials username 2279851457 password 7 12345 realm 64.34.181.47
authentication username 2279851457 password 7 12345 realm 64.34.181.47
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers trying 1000
timers connect 100
timers register 250
registrar ipv4:64.34.181.47 expires 200
sip-server ipv4:64.34.181.47
05-12-2011 05:59 PM
05-12-2011 06:02 PM
Still no go with this:
voice service voip
ipv4 64.34.181.47 255.255.255.255
sip
voice class h323 1
h225 timeout tcp establish 3
05-12-2011 06:01 PM
05-12-2011 06:03 PM
I had to do that in order to let the Call Manager to route calls too it, that is why there is the ip : 10.1.1.11 in the list.
But still no sip trunk connection...
What is this:
072468: May 12 20:03:50.935 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetRPCBFromRCB: Retreiving RCB [0x4ABB1098] from RPCB [0x0]
072469: May 12 20:03:50.935 CDT: //592/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
05-12-2011 06:22 PM
Cannot see from the supplied log that they are responding.
Maybe turn on additional sip debugging will give more insight or a local packet capture off the SBC will get plenty of information.
Either way I believe I would be contacting the carrier with questions about what changed. They will need to help indicate if something is off with their security.
05-13-2011 08:58 AM
Redacted, great word. Plus 5!
05-16-2011 04:38 PM
Found out it was my ISP blocking it.
06-27-2013 09:32 PM
Could you please clarify on what they were blocking?
