SIP Dial-peer fail over timer command to secondary sip dial-peer
Dominic Ellis
I was carrying out some testing yesterday with our provider.
We have 2 routes out to their 2 sip data centres.
They took the primary route down  so we could test that the backup route
to the secondary data centre worked ok in case of DR.
It worked - the call went through ok - but only after about 30 seconds of
trying the primary route.
Apparently there is a command to reduce the timer so that after only X seconds
the call will re-route to the backup route.
Does anyone know what that command is?
Dominic
good stuff guys. +5 each
Deji my friend I hope you are doing well.
Terry
8 Replies 8
Terry Cheema
You can tweak the number of retry and trying timer. Off the top of my head I think its 6 retries by default and timer doubling with each try.
Sip-ua
Retry invite 2
Timers trying x
Tweak above settings to get desired time.
Terry
Thanks Terry - I'll have a dig around.
Dominic
Not a problem mate. Please rate the useful posts and if you have no other queries please mark the thread as answered.
Terry
You may also want to consider SIP OPTIONS PING as a keepalive mechanism to busy-out the dial-peer when the connection is lost. Without this, the timer must expire for each call.
dial-peer voice tag voip
  voice-class sip options-keepalive
Please remember to rate helpful responses and identify helpful or correct answers.
+5 to Terry..Always good to see on the forum...guess you have been busy
+5 to Jonathan..Love your posts
Dominic,
Default SIP settings won't allow dial-peer failover to take place. The default number of SIP INVITE retries is 6 while the initial TRYING timer is 500 msec. In you case when the call arrive:
Initial SIP invite request
1st invite retry (delay to retry: ~500ms) 150ms
2nd invite retry (delay to retry: ~1sec)  300ms
3rd invite retry (delay to retry: ~2sec)
4th invite retry (delay to retry: ~4sec)
5th invite retry (delay to retry: ~8sec)
6th invite retry (delay to retry: ~16sec)
Failover time to second UAS      (delay to failover: ~32)
Note: Time delay increases using the formula (2xOld Time)
The total time to failover is 63.5 seconds
If you change your config to something like this
sip-ua
retry invite 2
timers trying 150
Failover will happen after 2 retries with a retry time of 150ms instead of the default 500ms
For more information please refer to this doc
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008082d76a.shtml
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Terry
Terry - thanks that has been a great help.
Dominic
Dominic not a problem, glad that helped.
