02-03-2018 02:42 PM - edited 03-17-2019 12:07 PM
Hi all,
We are configuring a new SIP Trunk to our new 2900 router that will be conneting to a our SIP Provider. Topology looks like: CUCM---SIP TRUNK - CUBE - SIP TRUNK - SIP PROVIDER
Currentely we are stuck trying to get the CUCM trunk up. We follow Cisco Guide and configure the trunk but the trunk is down with the Status Down reason remote=503.
PLEASE HELP...if you have any ideias what can cause this status reason. Please note debug and Sh run bellow
Feb 3 22:12:22.639: //-1/247870558004/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2B9F8040
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number :
Called Number :
Source IP Address (Sig ): 172.29.8.146
Destn SIP Req Addr:Port : 172.29.8.46:0
Destn SIP Resp Addr:Port : 172.29.8.46:39236
Destination Name : 172.29.8.46
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 200
Feb 3 22:14:25.087: //-1/6D7522878005/SIP/Call/sipSPICallInfo:
Calling Number :
Called Number :
Feb 3 22:16:27.515: //-1/B66E292C8006/SIP/Call/sipSPICallInfo:
Calling Number :
Called Number :
Current configuration : 4689 bytes
! No configuration change since last restart
version 15.1
hostname JPTLDAMAN-RTSIP-01
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 172.29.8.46
ipv4 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
shutdown
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-64
codec preference 4 g729r8
codec preference 5 g729br8
codec preference 6 g722-56
voice translation-rule 1
rule 1 /^0/ //
rule 2 /^000/ /00/
voice translation-rule 2
rule 1 /^222\(......\)/ /0222\1/
rule 2 /^9\(........\)/ /09\1/
rule 3 /^244222\(......\)$/ /0222\1/
rule 4 /^2449\(........\)$/ /09\1/
rule 5 /\(^.+\)/ /000\1/
license udi pid CISCO2911/K9 sn FCZ171260PS
hw-module pvdm 0/0
username cisco privilege 15 secret
redundancy
interface Loopback10
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
description RTACC08-00-G0/9
ip address 172.29.8.146 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description SIP To Angola Telecom
ip address 10.130.2.166 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0/0
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.29.8.1
logging trap debugging
control-plane
mgcp profile default
dial-peer voice 1 voip
redirect ip2ip
no modem passthrough
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay sip-notify rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax rate 14400
no vad
dial-peer voice 40 voip
translation-profile outgoing LocalRule
destination-pattern 2T
session target ipv4:172.29.8.46
voice-class codec 1
fax rate 14400
no vad
dial-peer voice 10 voip
translation-profile outgoing SIP-PSTN-OUT
destination-pattern ^02........$
redirect ip2ip
session target ipv4:66.110.114.133
voice-class codec 1
fax rate 14400
no vad
dial-peer voice 20 voip
destination-pattern 000T
redirect ip2ip
voice-class codec 1
dial-peer voice 50 voip
description #Emergency Calls#
destination-pattern 01..
voice-class codec 1
dial-peer voice 51 voip
destination-pattern 1..
voice-class codec 1
dial-peer voice 15 voip
destination-pattern ^09........$
redirect ip2ip
voice-class codec 1
sip-ua
gatekeeper
shutdown
line con 0
exec-timeout 9 0
privilege level 0
line aux 0
exec-timeout 9 0
privilege level 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
login local
transport input all
line vty 5 15
exec-timeout 9 0
privilege level 15
login
transport input all
scheduler allocate 20000 1000
end
Solved! Go to Solution.
02-03-2018 02:50 PM
02-03-2018 02:50 PM
ISSUE SOLVED.
JUst removed the shutdown comand in Voip Service.
