SIP trunk to provider
rbblue234
Hi All,
Currently using a cisco router as my SIP GW.  My hope is to use this router as my sip trunk to my provider.  When i call the number assigned to the gw im getting the following two entries in the debug.
//12/0E601AFD8035/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: failed to update call entry
//-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
below is my run.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.03.11 20:15:33 =~=~=~=~=~=~=~=~=~=~=~=
Using username "gwAdmin".
Using keyboard-interactive authentication.
Password:
VoIPGw>en
Password:
VoIPGw#sh run
Building configuration...
Current configuration : 3271 bytes
version 12.4
no service pad
hostname VoIPGw
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password Mansoor91111
aaa new-model
aaa session-id common
--More--                           !
dot11 syslog
ip source-route
ip cef
ip domain name VoIPGw
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
allow-connections sip to sip
redirect ip2ip
sip
  bind control source-interface FastEthernet0/0
--More--                             bind media source-interface FastEthernet0/0
  header-passing
  sip-profiles 1
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class sip-profiles 1
response ANY sip-header Allow-Header modify "invite, options, bye, cancel, ack, prack, update, refer, subscribe, notify, info, register" "invite, bye, cancel, ack, prack, subscribe, notify, info, register"
response 183 sip-header Allow-Header modify "ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, NOTIFY" "ACK, BYE, CANCEL, INFO, INVITE, PRACK, refer, notify"
response ANY sip-header Allow-Header modify "INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER" "INVITE, BYE, CANCEL"
response ANY sip-header Allow-Header modify "INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER" "INVITE, BYE, CANCEL, ACK, PRACK, SUBSCRIBE, NOTIFY, INFO, REGISTER"
--More--                           !
voice-card 0
no dspfarm
username gwAdmin password 0 Mansoor91111
archive
log config
  hidekeys
--More--                           !
ip ssh time-out 60
ip ssh authentication-retries 2
ip address <removed> 255.255.255.240
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
shutdown
interface FastEthernet0/1/2
interface FastEthernet0/1/3
--More--                           !
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Vlan1
description MGMT Vlan
ip address 192.168.10.52 255.255.255.0
interface Vlan4
description Server Vlan
no ip address
ip default-gateway <removed>
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
--More--                           no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
--More--                           voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
dial-peer voice 100 voip
destination-pattern <removed>
session target ipv4:192.168.10.51
session transport udp
dtmf-relay rtp-nte
no vad
sip-ua
--More--                            credentials username 138957_yup password 7 10620C0D1613423D5C0D3A6565 realm 138957_yup
authentication username 138957_yup password 7 10620C0D1613423D5C0D3A6565
registrar dns:newyork.voip.ms expires 3600
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
password cisco
transport input ssh
end
VoIPGw#               exit
Ayodeji Okanlawon
Is this the dial-peer you are using to send calls to your ITSP
destination-pattern
dtmf-relay rtp-nte
no vad
It is not configured correctly..You need to add
session protocol sipv2
Add that do another test and send
debug ccsip messages
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
14 Replies 14
Ayodeji Okanlawon
destination-pattern
dtmf-relay rtp-nte
no vad
DOH! Clicked the wrong button
The dial peer im using is trying too to deliver inbound calls to CUCM.
below is my updated dial peer config with sip messages.
destination-pattern
voice-class sip options-ping 60
dtmf-relay rtp-nte
VoIPGw#
VoIPGw#
VoIPGw#
*Mar 12 12:23:07.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:XXXXXX7522@XX.XX.134.24:5060 SIP/2.0
Via: SIP/2.0/UDP 74.63.41.218:5060;branch=z9hG4bK2d8e8860
Max-Forwards: 70
To: <>XXXXXX7522@XX.XX.134.24:5060>
Contact:
Call-ID: 5313cd90691bd5cd3a12d9b76bdeaaf7@74.63.41.218:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 12 Mar 2013 11:39:59 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Remote-Party-ID: "GARRETT " ;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 268
v=0
o=root 615418521 615418521 IN IP4 74.63.41.218
s=voip.ms
c=IN IP4 74.63.41.218
t=0 0
m=audio 15710 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*Mar 12 12:23:07.713: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 12 Mar 2013 12:23:07 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
INVITE sip:XXXXXX7522@192.168.10.51:5060 SIP/2.0
Via: SIP/2.0/UDP XX.XX.134.24:5060;branch=z9hG4bK1F488
Remote-Party-ID: "GARRETT " <>XXXXXX1293@XX.XX.134.24>;party=calling;screen=no;privacy=off
From: "GARRETT " <>XXXXXX1293@newyork.voip.ms>;tag=28C918C-3B4
To:
Call-ID: 6E47F727-8A4611E2-80D8EADC-2EFD56DE@XX.XX.134.24
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 1850090159-2319847906-2161306332-788354782
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1363090987
Contact: <>XXXXXX1293@XX.XX.134.24:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 294
v=0
o=CiscoSystemsSIP-GW-UserAgent 4747 6170 IN IP4 XX.XX.134.24
s=SIP Call
c=IN IP4 XX.XX.134.24
t=0 0
m=audio 17316 RTP/AVP 18 101 19
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Mar 12 12:23:07.721: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To:
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Received:
SIP/2.0 503 Service Unavailable
To: ;tag=1166479469
CSeq: 101 INVITE
Warning: 399 cucm "Unable to find a device handler for the request received on port 5060 from XX.XX.134.24"
Content-Length: 0
*Mar 12 12:23:07.729: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:XXXXXX7522@192.168.10.51:5060 SIP/2.0
To: ;tag=1166479469
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
SIP/2.0 500 Internal Server Error
To: <>XXXXXX7522@XX.XX.134.24:5060>;tag=28C919C-737
CSeq: 102 INVITE
Reason: Q.850;cause=63
Content-Length: 0
*Mar 12 12:23:07.813: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:XXXXXX7522@XX.XX.134.24:5060 SIP/2.0
Max-Forwards: 70
Contact:
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
Do you have a sip trunk configured on callmanager pointing to the ip address of your gateway?
Hello Aokanlawon.
Yes I do.
im now getting a 503 error message with an error code of
The ip address that's referenced in the error (removed from post) is the public IP address of the router.
So i went into CUCM and changes the IP address to be the public IP and still getting the same error.
I removed the bind command in the router and the sip messages are now showing the local ip address going to CUCM.
This has been fixed.
A few things i needed to change which is odd...  but what ever at this point.
I needed to add vad to the dial peer, added sipv2 session in the dial peer, and clicked media termination point required on the sip trunk.
below is my running config.
VoIPGw#sh run
Current configuration : 3588 bytes
version 12.4
no service pad
hostname VoIPGw
boot-start-marker
boot-end-marker
aaa new-model
--More--                           !
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
--More--                             header-passing
  early-offer forced
  midcall-signaling passthru
  g729 annexb-all
  sip-profiles 1
voice class codec 1
--More--                            response ANY sip-header Allow-Header modify "INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER" "INVITE, BYE, CANCEL, ACK, PRACK, SUBSCRIBE, NOTIFY, INFO, REGISTER"
request ACK sdp-header Audio-Attribute modify "sendonly" "sendrecv"
voice-card 0
dspfarm
dsp services dspfarm
--More--                           !
archive
log config
  hidekeys
ip address XX.XX.134.24 255.255.255.240
duplex auto
speed auto
no ip address
shutdown
shutdown
--More--                           !
interface Vlan1
interface Vlan4
no ip address
--More--                           ip default-gateway XX.XX.134.17
no ip http server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
--More--                           voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
--More--                            maximum sessions 8
shutdown
destination-pattern XXXXXX7522
dtmf-relay rtp-nte
sip-ua
line con 0
no modem enable
--More--                           line aux 0
line 2
no exec
transport input all
line vty 0 4
password cisco
transport input ssh
end
You dont need MTP...I suggest you dont use it..
FIrst of all you need to configure an inbound dial-peer from your ITSP
Eg..
dial-peer voice xx voip
incoming called number xxx (where XXX = is your DDI/DN pattern)
dtmf relay rtp-nte
no vad
Try this and remove the MTP on the sip trunk
On the Bind..
I noticed that the gateway is asking CUCM to send response back to the 50.20.134.24 ip....Can CUCM connect to this IP from the local interface?
What Interface does CUCM use to talk to the CUBE? Which IP have you configured for your sip trunk..You should put your bind on that IP
From the traces...
Via: SIP/2.0/UDP 50.20.134.24:5060
The CUBE is sending invite to CUCM on ip 192.168.10.51
HI,
Removing the media term point still allows calls to be placed.
When i change my dial-peer to be as follows...  the calls no longer route.  The deubg shows that there is no dial-perr match
incoming called-number XXX9177522
dtmf-relay rtp-nte
You need two dial-peers..I didnt say remove dial-peer 100..
You need an inbound and outbounbd dial-peer
Configure inbound dial-peer as follows
dial-peer voice 101 voip
dtmf-relay rtp-nte
Configure outbound dial-peer as follows
dtmf-relay rtp-nte
I have to admit that im really having a hard time here...
With your config i can get calls comming in with out issues.  I removed my programming and went directly with yours.
When i try and do an out bound call... well that failes.
I created the following dial peers. my CUCM will present 1+area code+ 7 digits
dial-peer voice 201 voip
incoming called-number 1.*
dtmf-relay rtp-nte
dial-peer voice 200 voip
destination-pattern 1.*
session target dns:neywork.voip.ms
dtmf-relay rtp-nte
below is my sip trace. Specific inforation removed and replaced with X's
*Mar 12 17:37:40.471: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:XXX9177522@50.20.134.24:5060 SIP/2.0
Via: SIP/2.0/UDP 74.63.41.218:5060;branch=z9hG4bK05a308ce
Max-Forwards: 70
To:
Contact:
Call-ID: 0468fe2415fdcd47074de44c25f3f433@74.63.41.218:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Tue, 12 Mar 2013 16:54:32 GMT
Content-Length: 268
v=0
o=root 805135302 805135302 IN IP4 74.63.41.218
s=voip.ms
t=0 0
m=audio 16470 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*Mar 12 17:37:40.487: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Tue, 12 Mar 2013 17:37:40 GMT
CSeq: 102 INVITE
Content-Length: 0
Sent:
INVITE sip:XXX9177522@192.168.10.51:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.52:5060;branch=z9hG4bK6B2285
Remote-Party-ID: "GARRETT " ;party=calling;screen=no;privacy=off
From: "GARRETT " <>XXXXXX1293@newyork.voip.ms>;tag=3AC8B58-E0D
To:
Call-ID: 5F5575A3-8A7211E2-831CEADC-2EFD56DE@192.168.10.52
Min-SE:  1800
Cisco-Guid: 1599316115-2322731490-2199317212-788354782
CSeq: 101 INVITE
Timestamp: 1363109860
Contact:
Expires: 180
Max-Forwards: 69
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 6223 2315 IN IP4 192.168.10.52
s=SIP Call
c=IN IP4 192.168.10.52
t=0 0
m=audio 19064 RTP/AVP 18 101 19
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
*Mar 12 17:37:40.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To:
CSeq: 101 INVITE
Content-Length: 0
*Mar 12 17:37:40.499: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17175193304@192.168.10.52:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.51:5060;branch=z9hG4bK122b41b544
From: "GARRETT " ;tag=a423d606-f845-422c-bf66-e67421ed9f12-33127376
To: <17175193304>
Call-ID: 81ab5980-13f15dc8-13-330aa8c0@192.168.10.51
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Contact:
Expires: 180
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 2175490432-0000065536-0000000019-0856336576
Session-Expires:  1800
P-Asserted-Identity: "GARRETT "
Remote-Party-ID: "GARRETT " ;party=calling;screen=yes;privacy=off
Max-Forwards: 68
Content-Length: 0
*Mar 12 17:37:40.511: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <17175193304>
CSeq: 101 INVITE
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <17175193304>;tag=3AC8B70-218F
CSeq: 101 INVITE
Reason: Q.850;cause=1
Content-Length: 0
*Mar 12 17:37:40.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17175193304@192.168.10.52:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar 12 17:37:40.519: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: ;tag=a423d606-f845-422c-bf66-e67421ed9f12-33127373
CSeq: 101 INVITE
Content-Length: 0
*Mar 12 17:37:40.523: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:XXX9177522@192.168.10.51:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar 12 17:37:40.527: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: ;tag=3AC8B7C-1E31
CSeq: 102 INVITE
Content-Length: 0
*Mar 12 17:37:40.611: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:XXX9177522@50.20.134.24:5060 SIP/2.0
Max-Forwards: 70
Contact:
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
i have this solved but not how i wanted too.
I went into my VoIP proivder and turned off the authenication for inound calls.  Since the GW will have a static, i told my VoIP proivder the IP and it will deliver every call too that IP.
every time i entered the below commands...  my inbound and outbound calls failed
config t
voice service voip
sip
outbound-proxy dns:newyork.voip.ms
Oh I can see where the error is..The destination-pattern is pointing back to CUCM. It should point to your sip provider
Try this..
incoming called-number . ( use . here)
dtmf-relay rtp-nte
destination-pattern XXXT ( this will match all the numbers you want to send out, change this to meet your dialled numbers)
session target ipv4:YYYYYYY (yyy=sip provider ip address
dtmf-relay rtp-nte
