3905 volume very low
bradley.huet
I have an issue with call volume on 3905 being extremely low. Is there any way of increasing the volume of the handsets beside the volume up and down keys on the phone. All the phone volumes are at maximum but the volume is very low. We using CUCM 8.6 as call processing server the firmware on the is 9.2.2.0
Any suggestion would be great
Hi Bradley,
we experiencing the same problem in one of our projects and we don't really know the problem.
Hope someone can explain it.
Thank you!
Guillermo
We have following bug raised for the issue.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue47452
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak
Thanks for this. Is this issue still going to be addressed.
Hi Bradley,
+5 to Ronak for kindly identifying this bug
This bug is marked as "Open & severity level 2 - Severe"
So this is actively being worked on
CSCue47452 - Low volume seen on the 3905 IP phones due to issue on DSPs
Description
Symptom:
Conditions:
Low Volume constantly seen on the 3905 IP phones, for incoming and outgoing calls.
Workaround:
None,  you may try to RMA the Phone and test
First Found in:                          (1)
9.2(1)
Status:
Open
Last Modified:
Feb 09,2013
Product:
Cisco Unified IP Phone 6900 Series
Platform:
Dependent
Severity:
2 - severe
You can mark this in your Bug watch via the Bug Search Tool and be notified when
a fix is available.
https://www.cisco.com/cisco/psn/bssprt/bss
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
