SIP Trunk Transcoding help
SHANE FREESE
I really just need pointed to the right documentation.  I've searched and I can't find it even though I know I've done this before.
Setup:
SIP Trunk --> 2821 --> PBX
The PBX is not a call manager.  We are using the 2821 basically as a SBC.  So SIP to SIP and everything works fine.  However some calls from the SIP provider come in as 729 instead of 711.  The PBX is not licensed for 729.  So I would like to configure transcoding on the 2821 to transcode those calls.  I have DSPs installed but I cannot find the documentation on how to configure the transcoding without a call manager on the other side.
Can someone point me in the right direction?
Ayodeji Okanlawon
CUBE based transcoder is similar to CME transcoder config. Attached is the Config guide..
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
10 Replies 10
Ayodeji Okanlawon
Thank you, I have followed the document exactly but the transcoder will not register.  Can anyone shed any light on something that I missed before I have to open a case with TAC?
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)
version 15.1
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
boot-start-marker
boot system flash flash:c2800nm-ipvoicek9-mz.151-4.M2.bin
boot-end-marker
logging buffered 5000
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice translation-rule 1
rule 1 /^89\(.*\)/ /\1/
voice translation-profile PSTN_Outgoing
translate called 1
voice-card 0
dsp services dspfarm
interface GigabitEthernet0/0
ip address 10.1.4.9 255.255.252.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
interface Serial0/2/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.1.7.254
control-plane
call fallback active
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.1.4.9 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE123456
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dial-peer voice 100 voip
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 89.%
session protocol sipv2
session target ipv4:12.X.X.X:5060
session transport udp
voice-class codec 1
voice-class sip options-keepalive down-interval 20 retry 2
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 101 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
preference 1
destination-pattern .......$
monitor probe icmp-ping 10.1.4.5
session target ipv4:10.1.4.5:5060
session transport tcp
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
huntstop
preference 2
monitor probe icmp-ping 10.1.4.7
session target ipv4:10.1.4.7:5060
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 400 voip
description **Incoming Call from SIP Trunk**
incoming called-number .%
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 202 voip
preference 1
destination-pattern 00000.%
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 203 voip
huntstop
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
retry invite 2
timers connect 100
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 XCODE123456
max-ephones 1
max-dn 1
ip source-address 10.1.4.9 port 2000
max-conferences 8 gain -6
transfer-system full-consult
line con 0
login local
line aux 0
line vty 0 4
login local
transport input all
router#sh sdspfarm units
mtp-1 Device:XCODE123456 TCP socket:[-1]  UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0* 0  Unknown 0 keepalive 0
max-mtps:1, max-streams:20, alloc-streams:0, act-streams:0
router#sho telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 1
max-dn 1
dspfarm units 1
dspfarm 1 XCODE123456
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
router#sh sdspfarm sessions active
router#
router#
router#
router#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: 10.1.4.9
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.4.9, Port Number: 2000
Priority: N/A, Version: 4.0, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 20, Reported Max OOS Streams: 0
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
router#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP   Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 10
Number of Resource Available : 10
Codec Configuration: num_of_codecs:6
Codec : g729br8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   28.3.2   UP     N/A  FREE  xcode   1      -         -         -
0    2   28.3.2   UP     N/A  FREE  xcode   1      -         -         -
Total number of DSPFARM DSP channel(s) 10
Change your the version for cme
put the latest that you can find in the config
Then no sccp , sccp
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Your configuration is wrong....
Please remove
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
what you need is this
telephony-service
sdspfarm units 1
max-ephones 1
max-dn 1
and the sccp config.
Please remove the dspfarm profile config..
shut down sccp and start sccp again
Actually I just shutdown telephone-service and brought it back up then the transcoder registered properly.  I will let you know if it actually works once we get some test calls placed.
It works perfectly.  Thanks for the help.
Hi aok
The above config that you mentioned is correct
Hi Freeses
Glad to hear that
one mention about trancoding
I believe that in order the trancoding to work properly then you have to remove the voice class from the specific dial peers
Otherwise the transode will not be involved
with show sccp connections you will verify if the trancoding work properly or not
cc
Chrys,
No it is not needed for internal based Transcoder on CUBE. This is similar to xcoding on CCME.
The command is used for external based transcoding where DSP is controlled by a call agent such as CUCM.
In this case, DSP resources are local to the CUBE and do not register with any external device...
Yes I did not change anything and it works properly now from what I can tell.  Since we have only come across 4 numbers where the codec mismatches it doesn't pop up very often so it is hard to catch using a sh sccp connections.  I am going to leave the codec list in place since at this time it doesn't seem to be causing any issues.
