12-26-2012 03:38 AM - edited 03-16-2019 02:52 PM
I have following senario:
IP Phone(3400)---> CME--->Internet----->SIP Proxy
SIP Proxy Server: xyz.com
SIP Username: xuser
SIP Password: password
While the call is being send to the SIP Proxy, is looks like this:
INVITE sip:009123232323@xyz.com:5060 SIP/2.0
Via: SIP/2.0/UDP 91.140.172.32:5060;branch=z9hG4bK92D1AF1
Remote-Party-ID: "xuser" <sip:3400@91.140.52.20>;party=calling;screen=no;privacy=off
To: <sip:00912923232323@xyz.com>
Next rejects the call because of the 404- Not found message:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 91.140.52.20:5060;rport=57925;branch=z9hG4bK92D1AF1
To: <sip:009129623232323@xyz.com>;tag=as4ddaa55f
Call-ID: DEFDA60D-4E8511E2-8F86B5C9-5A38862F@91.140.52.320
I believe that the issue here is that CME is sending the phone callerid as SIP user name. Actually, the invite message should like this:
Could someone please advise, how to force CME to do this?
Saif
12-26-2012 05:00 AM
There can be another reason. Beside, sending calling number is correct. Ask first why the call is rejected.
12-26-2012 09:24 PM
Paolo,
The reason for call rejection is very clear from the logs. username "3400" is unknown to proxy server and so it sends error 404 - user not found.
saif
12-26-2012 05:09 AM
Are you sure the called number actually could be reach?
Please rate all useful posts
_____________________________
MDGDP, CCNA, CCNA Voice certified
12-26-2012 09:25 PM
Yes, the called number is absolutely reachable. When used the same credentials on a SIP client like Xlite, it dial the number very well and everything looks good there.
saif
