SIP Trunk with multiple remote servers
Hay,
       I am new to cisco IP telephony.I have just configured a SIP trunk b/w Asterisk and cisco2800 router.Now i want to create another trunk with Avaya with the first one with Asterisk also working i am confused how to do this.
below is my config on router
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$ml.W$gFgeC4R3cZwYLfDULvXx81
enable password xxxx
no aaa new-model
resource policy
no network-clock-participate wic 1
ip subnet-zero
ip cef
voice-card 0
 no dspfarm
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 redirect ip2ip
 signaling forward unconditional
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
controller E1 0/1/0
controller E1 0/1/1
 ip address 192.168.200.41 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip classless
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
 cptone PK
 connection plar opx 7500
 caller-id enable
voice-port 0/0/1
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
no mgcp explicit hookstate
dial-peer voice 7500 voip
 destination-pattern 7500
 session protocol sipv2
 session target ipv4:192.168.200.170          //ip of astersik server
 codec g711alaw
 no vad
dial-peer voice 100 pots
 destination-pattern 0T
 port 0/0/0
 forward-digits all
sip-ua
 retry invite 3
 retry response 3
 retry bye 3
 retry cancel 3
 timers trying 100
 sip-server ipv4:192.168.200.170           //////ip of asterisk server
telephony-service
 max-conferences 8 gain -6
line con 0
line aux 0
line vty 0 4
 password xxxx
 login
line vty 5 15
 password xxxxx
 login
scheduler allocate 20000 1000
end
Router#
2 Accepted Solutions
Chris Deren
Simply define the destination on a dial-peer as you can only have one sip-server, i.e.
dial-peer voice 7501 voip
 destination-pattern XXXX
 session target ipv4:x.x.x.x         //ip of Avaya
 codec g711alaw
 no vad
That is no different from what I already provided.  The sip-server is nothing more than central place for defining the destination and then pointing to from dial-peers, having a specific destination on the dial-peer overwrites it. So, if you have multiple sip destinations you just define them on appropriate dial peers.
Chris Deren
 codec g711alaw
 no vad
Thanks Chris,
                       Bundles of thanks for prompt support.
What if i have both servers on local network/interface .Actually i have two PABX Avaya and Asterisk on local network 192.168.200.0 .I want to connect both two cisco 2800 via sip so that both PABX can be reached via each other.
Can you help configure i dont know how to add two sip servers
