SSH User creation on CUCM using CLI
sravan.at
I am using CUCM 10.5.2 and need to create a SSH user using CLI. Can anybody please let me know the steps.
Thanks in advance.
Debasis
Manish Gogna
Hi Debasis,
You can use the "set account name" command as explained here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/10_5_2/CUCM_BK_CA8D6D40_00_cucm-cli-reference-guide-1052/CUCM_BK_CA8D6D40_00_cucm-cli-reference-guide-1052_chapter_0110.html#CUCM_CL_S108E423_00
Manish
- Do rate helpful posts -
Manish Gogna
Hi Debasis,
Manish
one note:
After you enter the username, the system prompts you to enter the privilege level (0 or 1) and password for the new account. The privilege levels definitions are as follows:
Privilege level 0
Specifies an ordinary privilege level. Users with ordinary privileges can run CLI commands with privilege level 0 only.
Privilege level 1
Specifies an advanced privilege level. Users with advanced privileges can run CLI commands with privilege level 1 and below.
The administrator account that the system creates when Unified Communications Manager installs has a privilege level of 4. The administrator can run all commands in the CLI.
Tiago Marques
if I'm not mistaken, the user to SSH connection, must be the user the OS ADMIN!
