SIP trunking between CUCM 9.1 and Avaya IPO 500v2
Hello
I have a problem regarding SIP trunking between CUCM9.1 and Avaya IP Office.
I have configured Avaya and Cisco call managers via this document:
http://www.devconnectprogram.com/fileMedia/download/d5378279-b4bb-47a3-995d-1e21aef0b524
After it calls from Avaya to CUCM goes and SIP works fine, but from CISCO to Avaya I receive fast busy tone.
Can somebody help me, please?
Questions are never stupid, sometimes answers may be :)
Although you have only shared trace image, not live traces, but I can see that CUCM is still sending INVITE without SDP.
Can you double check;
1. You have created new SIP profile as you can not edit default SIP profile.
2. Early offer is enabled as per following under SIP profile;
3. This newly created SIP profile is assigned to respective SIP trunk.
4. You save the configuration and reset the SIP trunk.
5. In unforeseen condition, below is the comment I got for similar issue (thread I shared with you earlier);
Finally I got it working perfect.You all were right but reset did not validate the settings for me, I went for a complete restart and it worked.
Vivek
9 Replies 9
j.huizinga
Level 6
Level 6
Check log files on Cisco and Avaya
JH
Vivek Batra
Apart from JH has mentioned, please check the following thread;
https://supportforums.cisco.com/discussion/12462591/sip-trunk-cucm-9-avaya-ip-office-500-v2-issues
sorry for my stupid questions, but I am at a loss.
I have configured my cucm and avaya call managers as described in the Avaya devconnect integration document, and ticked the checkbox, then I have restarted sip trunk, phone, and dial pattern. But no effect.
I have attached wireshark capture. 192.168.0.145 is CUCM, 192.168.90.1 is IPO
Vivek
I did all these, and no differences.
Maybe I misconfigure dial pattern (although I config CUCM and Avaya as in devconnect document mentioned)??? Because when I place a call on CIPC there writes "to unknown number", and no busy tone, only silence.
Hello
I am so sorry for disturbing you, but can you go over this link, I have recorded how config the CUCM.
https://www.youtube.com/watch?v=6WgAEBXXyCY
May be I have done something wrong???
Thanks in advance
This is log output from Avaya
********** SysMonitor v9.0.6.0 build 979 [connected to 192.168.90.1 (00E007090044)] **********
 11:00:08    2670716mS PRN: Monitor Status  IP 500 V2 9.0.6.0 build 979
 11:00:08    2670716mS PRN: LAW=A PRI=0, BRI=2, ALOG=4, VCOMP=20, MDM=0, WAN=0, MODU=0 LANM=0 CkSRC=0 VMAIL=1(VER=3 TYP=1) 1-X=0 CALLS=0(TOT=2)
 11:00:17    2679420mS SIP Rx: TCP 192.168.0.145:36455 -> 192.168.90.1:5060
                    INVITE sip:201@192.168.90.1:5060 SIP/2.0
                    Via: SIP/2.0/TCP 192.168.0.145:5060;branch=z9hG4bK2725bbbe9
                    From: <sip:1001@192.168.0.145>;tag=294~d8f9dc19-08cf-4989-8ff1-1e0480b56e08-18688994
                    To: <sip:201@192.168.90.1>
                    Date: Tue, 05 May 2015 07:00:38 GMT
                    Call-ID: 6e027480-54816a96-25-9100a8c0@192.168.0.145
                    Supported: timer,resource-priority,replaces
                    Min-SE:  1800
                    User-Agent: Cisco-CUCM9.1
                    Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
                    CSeq: 101 INVITE
                    Expires: 180
                    Allow-Events: presence, kpml
                    Supported: X-cisco-srtp-fallback,X-cisco-original-called
                    Call-Info: <sip:192.168.0.145:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
                    Cisco-Guid: 1845654656-0000065536-0000000046-2432739520
                    Session-Expires:  1800
                    P-Asserted-Identity: <sip:1001@192.168.0.145>
                    Remote-Party-ID: <sip:1001@192.168.0.145>;party=calling;screen=yes;privacy=off
                    Contact: <sip:1001@192.168.0.145:5060;transport=tcp>
                    Max-Forwards: 70
                    Content-Length: 0
 11:00:17    2679424mS CMCallEvt:    0.1014.0 -1 BaseEP: NEW CMEndpoint f4ec4b48 TOTAL NOW=1 CALL_LIST=0
 11:00:17    2679427mS SIP Tx: TCP 192.168.90.1:5060 -> 192.168.0.145:36455
                    SIP/2.0 100 Trying
                    CSeq: 101 INVITE
                    Allow: INVITE,ACK,CANCEL,OPTIONS,BYE,INFO,REFER,NOTIFY,UPDATE
                    Supported: timer
                    Server: IP Office 9.0.6.0 build 979
                    To: <sip:201@192.168.90.1>;tag=4f3773fe962fef8f
                    Content-Length: 0
 11:00:17    2679429mS SIP Tx: TCP 192.168.90.1:5060 -> 192.168.0.145:36455
                    SIP/2.0 503 Service Unavailable
                    CSeq: 101 INVITE
                    Supported: timer
                    Reason: Q.850;cause=88;text="Incompatible destination"
                    Content-Length: 0
 11:00:17    2679435mS SIP Rx: TCP 192.168.0.145:36455 -> 192.168.90.1:5060
                    ACK sip:201@192.168.90.1:5060 SIP/2.0
                    Max-Forwards: 70
                    CSeq: 101 ACK
                    Content-Length: 0
 11:00:17    2679734mS RES: Tue 5/5/2015 11:00:17 FreeMem=54908088 54665440(3) CachedMem=242648 CMMsg=2(3) Buff=5200 1369 999 7428 5 Links=6221 BTree=14584 CPU=04.24% CPUStats=13/23/13080/14551/17104/0/0 MCR=0 MCW=0
 11:00:17    2679734mS RES2: IP 500 V2 9.0.6.0 build 979 Tasks=53 RTEngine=0 CMRTEngine=0 ExRTEngine=0 Timer=62 Poll=0 Ready=0 CMReady=0 CMQueue=0 VPNNQueue=0 Monitor=2 SSA=1 TCP=22(TLS=4) TAPI=0 ASC=1 SYS=MNTD OPT=UMNT SDSPD=2034
 11:00:17    2679734mS RES4: XML MemObjs=61 PoolMem=2097152(1) FreeMem=2081872(1)
 11:00:18    2680437mS CMCallEvt:    17.1014.1 -1 SIPTrunk Endpoint: StateChange: END=X CMCSIdle->CMCSDelete
 11:00:18    2680438mS CMTARGET:     17.1014.1 -1 BaseEP: ~CMTargetHandler f4ec6888 ep f4ec4b48
 11:00:18    2680438mS CMCallEvt:    17.1014.1 -1 BaseEP: DELETE CMEndpoint f4ec4b48 TOTAL NOW=0 CALL_LIST=0
 11:00:18    2680519mS H323Evt:    Recv: RegistrationRequest   192.168.90.30; Endpoints registered: 1; Endpoints in registration: 0
********** Warning: Logging to Screen Stopped **********
Finally it works!!!
So, in the Avaya DevConnect integration guide, at the page 10, there is an option to tick "Media Termination Point Required" checkbox, I disable it.
And it works with enabled option "Early Offer" in the SIP Profile.
Thanks again.
Glad to know you got it solved.
