08-22-2018 01:32 AM - edited 03-17-2019 01:22 PM
Hi All
A quick quesiton, when we configure a SIP trunk to an ISP on the CUBE, we get given the dns or IP of the SBC of the ISP.
Do they need to know the IP of the CUBE our side and do the same config by routing calls to our CUBE for inbound?
Solved! Go to Solution.
08-22-2018 04:38 AM
@carl_townshend wrote:
Hi All
Yes that is correct. They will need to know where to send the traffic to.
08-22-2018 04:38 AM
Hi All
08-22-2018 04:50 AM
You have to know the provider using IP or FQDN
And they have to know you using IP or FQDN
JH
