SIP-UA Missing Header issue
Rizwan Haider
we are trying to register Etisalat SIP via registrar dns:vims-siptrunk.etisalat.ae but getting 401 unauthorized from telco. They are saying we have to send another request with header including domain name, credentials and MD5 encryption. As per Etisalat, we are missing header. any one who did configuration from CUCM > 2900 voice gateway >> Telco ONT >> Telco.
sip-ua
credentials username +97142746222@ims.etisalat.ae password 7 1315062A1209337D6F realm ims.etisalat.ae
authentication username +97142746222@ims.etisalat.ae password 7 0103173C420E315865 realm ims.etisalat.ae
registrar dns:vims-siptrunk.etisalat.ae expires 3600
20 Replies 20
I will try the same tomorrow during downtime and will post here.
Thanks.
But be aware: which way to configure it, depends on the format of username in the Authentication header, recieved by provider (in the RE-REGISTER message from CUBE to provider):
  • If the provider wants the username delivered in the format "username" --> you can use Rogers config example
  • If the provider wants the username delivered in the format "username@domain" --> you need to use my config example
But maybe you are lucky and the provider supports both formats.
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
icisse
Hi everybody,
I am trying to register SONATEL SIP via registrar ipv4:X.X.X.X using sip-ua.
SIP/2.0 400 Bad Request
Via: SIP/2.0/UDP 192.168.92.6:5060;branch=z9hG4bK1221ED;received=41.67.115.164;rport=61367
Call-ID: 4F0E08B0-AF511EF-8009B926-1BC6EFE9
To: <sip:anonymous@anonymous>;tag=88gp82xq
CSeq: 3 REGISTER
Warning: 399 10.131.1.6 "SS280000F65602L8655264[00000] From header absent or undecipherable",399 16.161.1.6 "SS280000F65602L11997600[00000] To header absent or undecipherable"
Content-Length: 0
My sip-ua configuration :
sip-ua
credentials number +221339212200 username +221339212200 password 7 132831305A5D250919 realm ims.sonatel.sn
authentication username +221339212200 password 7 12342335435A2D2718
no remote-party-id
timers connect 100
registrar ipv4:10.131.1.6 expires 3600
sip-server ipv4:10.131.1.6:5060
Advice you to create your own post to ask your question as this post is marked as Solved and your question isn’t directly on-topic with the OP.
Response Signature
Thanks you !
I'm going to create a post about that.
