sip-ua with sipgate Germany
Alexander Gomer
Hi Guys,
I try to implement Sipgate (Germany) as ISTP.
I see that the trunk get registred with:
- show sip-ua register status
- configuration website from Sipgate
Unfortunately the registration drops, the status of the trunk from the website is offline but show sip-ua register status tell me the trunk is registered.
I use this cfg on gateway:
voice service voip
ip address trusted list
  ipv4 217.10.68.150 255.255.255.255
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  min-se 28800 session-expires 28800
  bearer-capability clear-channel udi
sip-ua
credentials number 111111T0 username 111111T0 password 7 XXXXXXX realm sipconnect.sipgate.de/111111T0
authentication username 111111T0 password 7 XXXXXXX realm sipconnect.sipgate.de/111111T0
retry invite 5
retry register 10
timers connect 100
registrar dns:sipconnect.sipgate.de:5060 expires 3600
sip-server dns:sipconnect.sipgate.de:5060
dial-peer voice 50 voip
translation-profile outgoing SIP
destination-pattern 41T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
If the trunk is registered on both sides, incoming calls working fine.
But outgoing calls doesn't work at all.
So currently I'm facing two issues:
1. registeration drops
2. outgoing calls don't work --> SIP/2.0 403 Forbidden (check from field)
For the frist issue, this output lookings strange to me:
VGW_1#show sip register stat
Line                             peer       expires(sec) registered P-Associ-URI
0*                               2          125          no
111111T0                         -1         2202         yes
I don't know where the 0* is coming from. But it also tries to register at Sipgate Oo
For the second issue, I guess it would work if I could use this cfg on outgoing SIP dial-peer:
clid network-number 111111T0
But I can't implement it, because there is a letter in it.
Running IOS version: 15.1(4)M1
Please advise
paolo bevilacqua
Wrong forum, post in "IP telephony". You can move your posting with the Actions panel on the right.
