SMART Licenses - SRST
bstrubeTD3
I have opened a ticket with Cisco but I want some input from the community. I have deployed ISR4331 routers. When I do SMART Licensing, it applies 110 SRST License which is the max that the router can do.  I have several sites that have a lot fewer licenses, such as 40 or 50 licenses, so I don't need to apply all of these licenses. If I do then I run out of SRST licenses.  For example, I have 24 ISR4331 routers, so if I use 110 at each site then I would need 2640 licenses and I only have about 1550 SRST licenses to cover the actual phones I have.
I was told by Cisco that SRST licenses are counted as the sum of the max-pool (under voice register global) and max-ephones (under telephony-service). Also I have some schools that use SCCP and some that use SIP. So if I have school that has 50 phones, I want to use 50 SRST license (not 100 or 110). What is the solution to get the correct number of licenses for a school? Does the solution change on whether it is a SIP or SCCP site?
A snippet of the config:
default mode
no allow-hash-in-dn
max-dn 400
max-pool 110
external-ring Bellcore-dr3
voice register pool  1
translation-profile incoming TransSRST
id network 10.1XX.1.0 mask 255.255.255.0
proxy 10.1XX.1.2 preference 5 monitor probe icmp-ping
no digit collect kpml
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 4
sdspfarm transcode sessions 12
sdspfarm tag 2 CFB-Connolly
sdspfarm tag 3 MTP-Connolly
sdspfarm tag 4 XCD-Universal
conference hardware
mode esrst
srst mode auto-provision all
srst ephone template 1
srst ephone description srst fallback : Jun 20 2019 08:13:18
srst dn template 1
srst dn line-mode dual-octo
max-ephones 100
max-dn 200
ip source-address 10.1XX.1.2 port 2000
max-redirect 20
service directed-pickup gpickup
timeouts interdigit 3
timeouts busy 30
time-zone 7
keepalive 10
bulk-speed-dial prefix ##
max-conferences 8 gain -6
call-park system redirect
call-park system application
call-forward pattern .T
moh enable-g711 "flowingwaters.alaw.wav"
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
Any help is appreciated with this
HARIS_HUSSAIN
As per the guide it is just upper license limit. You can purchase the required number of SRST licenses and register in Smart Account. No
The license limit on Unified SRST is restricted by the maximum platform limit defined for the Unified SRST router (a cumulative sum of phones configured under max-pool and max-ephone).
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_sip_isr4000.html
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
